Kirjoittaja Aihe: Hpi Hellfire 1/8  (Luettu 39164 kertaa)
Poissa Joona H
Hpi Hellfire 1/8
« : 02.09.05 - klo: 19.51 »
:shock:
Tässä sitten specsejä kopsattuna Jenkkifoorumilta:
Coming soon from HPI Racing is the Hellfire, a purpose built, Ready-to-Run high performance, 1/8 scale four wheel drive monster truck. The Hellfire offers maximum performance in all conditions by combining the durability characteristics of the Savage with the agility of 1/8 scale buggies. The truck has a wide range of tuning adjustments, is extremely lightweight and features all-new suspension and steering geometries. It has been designed to allow for easier maintenance with simplified differential access, high quality hex hardware and no e-clips are used anywhere.
The Hellfire will sit along side the Savage in the HPI monster truck line-up. The Hellfire is fast, low and aimed at track enthusiasts, while the Savage is a proven “basher” with oversized durability and maximum ground clearance. Both trucks will be available in ready-to-run and kit versions.
Due for release before the end of the year, stay tuned for more information on the Hellfire.
Hellfire features:
• Purpose built high performance monster truck right out of the box. This is not a buggy conversion!
• Internal drive ratio is optimized for .21 and .28 size race engines.
• Steering and suspension geometries are designed specifically for this truck to maximize performance.
• Low center of gravity for increased responsiveness and better chassis balance.
• The front and rear differentials can be removed by taking out six screws.
• The removal of four screws allows access to the center differential.
• No e-clips are used, anywhere!
• Hex sockets reduce the possibility of a stripped screw.
• Adjustable front and rear inboard toe with convenient urethane eccentric bushings.
• Front inboard toe angle adjustments: 0 degrees to -2 degrees.
• Rear inboard toe angle adjustments: 2 degrees to 4 degrees.
• Adjustable front and rear camber using strong steel turnbuckles.
• The camber can be fine tuned to suit your track conditions.
• Anti-dive adjustments: 0 degrees to 2 degrees in 0.5 degree increments.
• Anti-squat adjustments: 1.5 degrees to 3.5 degrees in 0.5 degree increments.
• Front kick-up angle: adjustable from 21 to 25 degrees.
• 24 possible shock positions available to fine tune your suspension.
• Spring clips are included to fine tune your ride height.
• Four different shock pistons are included for a wide range of tuning options.
• Different compression and rebound can be achieved with tapered shock pistons.
• Damping can be fine tuned with different diameter holes.
• Adjustable steering geometry.
• Adjustable brake bias to control entry steering and jumping.
• Chassis braces included to adjust overall chassis stiffness for smooth or bumpy tracks.
• New, high RPM .28 K4.6 HO engine with increased HP and torque.
• Hard anodized exhaust pipe for maximum power.
• High flow 2 stage air filter for maximum engine protection and increased engine performance.
• Continuous radius exhaust header for maximum exhaust flow and power.
• Wire routing protects wires from moving parts.
• Fuel tube routing system prevents line breakage and promotes better fuel delivery.
• Fuel splash guard keeps fuel splashes away from the brake disk and drivetrain.
• 150cc fuel tank for longer run times than buggy spec 125cc equipped trucks.
• Internal fuel tank filter and external high quality fuel filter for maximum engine protection.
• Low center of gravity flush mounted radio box.
• Secure transponder mounting system.
• 1100 mah, 5-cell receiver pack with 2 hour wall charger included.
• New high strength aero dish wheel with 17mm hex for added durability.
• All driveshafts are CV style joints maximum durability and high efficiency.
• 3.5mm titanium nitride coated shock shafts for durability and maximum performance.
• Titanium nitride suspension pins are extremely durable and provide smooth suspension action.
Näyttäis olevan aika hemmetin makea peli,vaikka tuonne tulevaan Arena Monster Truck-kisaluokkaan 8)
Poissa Juuzmo
Hpi Hellfire 1/8
« Vastaus #1 : 02.09.05 - klo: 19.58 »
UI UI  :shock:  Paljon tollasella pelillä hintaa on? muistuttaa vähän niinku hot bodies lsp mutta vähemmän alumiinia  :D
RB,the power of champions.
Poissa Toni N
Hpi Hellfire 1/8
« Vastaus #2 : 02.09.05 - klo: 20.00 »
Ai perhana kun vaikuttaa hienolta peliltä.
Nyt ei auta muu kuin odotella maltilla. Makeita ratkaisuja diffien osalta jne.
Tyhjä
Poissa Jose.92
Hpi Hellfire 1/8
« Vastaus #3 : 02.09.05 - klo: 20.03 »
Toi on kyllä mun seuraava auto. Ainaa melkei
Poissa rs tuning
Hpi Hellfire 1/8
« Vastaus #4 : 02.09.05 - klo: 20.20 »
No nyt tulee HPI:ltä pätevän näkönen kisa monsteri :shock:
Poissa Esto_r
Hpi Hellfire 1/8
« Vastaus #5 : 02.09.05 - klo: 20.47 »
No hitto vie nyt harmittaa ku menin hpi 18ss ostamaan!!!! :cry:
Hpi mt2 18ss
Poissa Esto_r
Hpi Hellfire 1/8
« Vastaus #6 : 02.09.05 - klo: 20.48 »
Hpi mt2 18ss
Poissa Hermanni
    • Kotisivuni
Hpi Hellfire 1/8
« Vastaus #7 : 02.09.05 - klo: 21.09 »
Näyttää siltä että HPI:nkin väki on seurannut "jenkkien" Arena Monster Truck luokan sääntökehitystä koska tankki on "vain" 150cc!
Myöskin nyt kun säännöt ovat "heilläkin" yhtenäistyneet, tuovat auton ja sen speksit julki.  :wink:
Veikkaan että takulla on kova "rauta" tuo Hellfire radalla (Matala kuin mikä).......
Poissa Juuzmo
Hpi Hellfire 1/8
« Vastaus #8 : 02.09.05 - klo: 21.12 »
Tuo muituttaa enemmän stadium truckia kuin monsteria  :roll:  aika matala on meinaan  :shock:
Poissa Jose.92
Hpi Hellfire 1/8
« Vastaus #9 : 02.09.05 - klo: 21.14 »
Nimi on kyllä hupaisa :mrgreen:
Poissa Joona H
Hpi Hellfire 1/8
« Vastaus #10 : 02.09.05 - klo: 21.16 »
Kumma kun ei ole Roto-Startia............ehkä sitten tuotantoversioon :)
Poissa Tomsson
  • Ulvilan RC-rata
Hpi Hellfire 1/8
« Vastaus #11 : 02.09.05 - klo: 22.17 »
Joo, itsekin katoin että wtf monsu.
Hienohan auto on, mutta ei mene läpi monsuna sitten millään meikäläiselle :)
allekiroitus
Poissa Toni N
Hpi Hellfire 1/8
« Vastaus #12 : 02.09.05 - klo: 22.21 »
Aivan, monsu ja monsu...
Todella nätti auto, ja varmasti nopea radalla, mutta kyllä se taitaa itselläni olla kuitenkin ihan varsinaiselle monsulle enemmän tarvetta. Kisakalustoa ja sudittelumonsua tuskin viitsii hommata erikseen, kun pitäisi vielä ylläpitää ajohaluja on-roadinkin puolella.
Esim. tuolla Hellfirellä ei meikäläisen mökkiradalla olisi mitään toivoa, ja siellä meikäläisen ratamonsuilu pääasiassa tapahtuu.
Noh, aika näyttää.
Tyhjä
Poissa Juuzmo
Hpi Hellfire 1/8
« Vastaus #13 : 02.09.05 - klo: 22.26 »
Arviolta sanoisin että tuon maavara on noissa kuvissa ainakin samaa luokkaa kun stadium truckeissa,5 cm luokkaa??
Poissa waltt
Hpi Hellfire 1/8
« Vastaus #14 : 02.09.05 - klo: 22.30 »
mun mielest toi auto näyttää melko paljon hpi nitro mt kakkoselt... ainaki äkkii katottun... mut on niis silti nii paljo eroo...
Hyper 7 TQ, Rc18T, Mini-z AWD
Hobao.        Asso.    Kyosho
Poissa Divi
Hpi Hellfire 1/8
« Vastaus #15 : 02.09.05 - klo: 23.47 »
Lainaus käyttäjältä: "waltt"
No ainakin kokoluokka on eri  :wink:
Poissa Joona H
Hpi Hellfire 1/8
« Vastaus #16 : 03.09.05 - klo: 19.37 »
Poissa Rph
  • Ulvilan RC-rata
Hpi Hellfire 1/8
« Vastaus #17 : 04.09.05 - klo: 18.21 »
Tuohan on Hotbodiesin tekemä, ja aikaslailla kopio Lightning stadium prosta. Täytyypi tilata moinen :wink:  lähempää tutkailua varten. Tosin tuo muovisuus askarruttaa kyllä.
mydään lennokipiruustuksia .)
Poissa Joona H
Hpi Hellfire 1/8
« Vastaus #18 : 04.09.05 - klo: 18.41 »
Lainaus käyttäjältä: "Rph"
Missäs noin sanotaan?
Ja ei tuo minusta muistuta juurikaan LSP:tä,vaikka onhan nuo Truggyt aika samanlaisia kaikki :)
Poissa Juuzmo
Hpi Hellfire 1/8
« Vastaus #19 : 04.09.05 - klo: 18.44 »
Lainaus käyttäjältä: "Joona H"
tankki näyttäs olevan melko samassa kohdassa ja muutenkin muistuttaa hottia  :roll:  alumiinia on tosin vähemmän  :D
Poissa Joona H
Hpi Hellfire 1/8
« Vastaus #20 : 04.09.05 - klo: 18.48 »
Lainaus käyttäjältä: "Juuzmo"
Juu onhan se,ihan niin kuin jok'ikisessä markkinoilla olevassa Truggyssa :lol:
Poissa Juuzmo
Hpi Hellfire 1/8
« Vastaus #21 : 04.09.05 - klo: 19.11 »
No se nyt oli sellanen vertaus kuva  :roll:  :lol:
Poissa JK Nitro
Hpi Hellfire 1/8
« Vastaus #22 : 04.09.05 - klo: 20.23 »
Eihän se alumiini autosta kestävää tee, vierestähän se sitten poikii kun tälli tulee.
RPH silminnäkijänä muistaa lauantailta mun savagen voltit Ulvilan radan keskivaiheilta olevasta hyppyristä. Omia sanojasi lainaten: "ei olis Hotti tosta selvinnyt", siinä olis videon paikka ollut :mrgreen:  .
Monesti hyvälaatuinen muoviosa voittaa sitkeydellään ja joustavuudellaan alumiinin. Joissain paikoissa toki pitää aluakin olla, että muoviosat pysyy tukevasti paikoillaan.
Poissa Juuzmo
Hpi Hellfire 1/8
« Vastaus #23 : 04.09.05 - klo: 20.28 »
Lainaus käyttäjältä: "JK Nitro"
Olinko minä lähtenyt jo silloin? Olin siis se liekkihattunen tyyppi millä oli pieni räppänä auto mikä ei toiminut  :mrgreen:
Poissa Rph
  • Ulvilan RC-rata
Hpi Hellfire 1/8
« Vastaus #24 : 04.09.05 - klo: 20.32 »
Oikeassa olet Hotista olisi breissit menny rikki, mutta oli hienoa katsoa kun tehokkaat blingbling :wink:  Savaget meni radalla ja vielä hyvillä kierrosajoilla.
Poissa JK Nitro
Hpi Hellfire 1/8
« Vastaus #25 : 04.09.05 - klo: 20.34 »
Enpä muista varmaksi, saattoi olla, että kerkesit lähtemään.
Se lento oli sellasta 5-6 vaakakierrettä kerien 2-3 kertaa sitä suoja aitaa pitkin. Hiukka hirvitti kyllä, että kuis käy, mutta mitä vielä, kovaa ajoa vaan.
Sori OT, ei sen enempää täällä siitä. :|
OT 2: Takapäästä se blingbling kyllä sai lähteä, kun se meni aika väkkäräksi sillä reissulla. En kyllä tiedä tarviiko sitä, mutta kyllä sen varmaan vielä suoristaa.
Paikalla tapsa92
Hpi Hellfire 1/8
« Vastaus #26 : 05.09.05 - klo: 16.28 »
Tolla autolla on aikas uhkarohkee nimi :lol: .
Poissa Teemus.
Hpi Hellfire 1/8
« Vastaus #27 : 08.09.05 - klo: 18.04 »
TÄÄ AUTO MAKSAA TOWERISSA 898 E!!!!! pitääkö paikkansa??
AE RC10T4 ja HBX 4WD Buggy
Paikalla tapsa92
Hpi Hellfire 1/8
« Vastaus #28 : 08.09.05 - klo: 18.10 »
No kai se sit pitää paikkansa, jos siellä kerran niin sanottiin.
Poissa Svg
    • http://www.geocities.com/rcmikko
Hpi Hellfire 1/8
« Vastaus #29 : 08.09.05 - klo: 18.13 »
Lainaus käyttäjältä: "Teemus."
Ajattelin ostaa ton, mutta jos hinta tosiaan on tommonen niin ei taida budjetti riittää :?
