Kirjoittaja Aihe: HPI Baja 5b Gas Buggy 1:5  (Luettu 30973 kertaa)
Poissa Joona H
« : 02.09.05 - klo: 19.59 »
Jos Hellfire oli makea,niin entäs sitten tämä :shock: :
Sitten vähän specsejä:
Coming soon from HPI Racing is the Baja 5B, a giant Ready-to-Run 1/5 th scale off-road buggy that is nearly 32” in length! The big size allows the Baja 5B to go where smaller buggies can’t, and the driving experience is as close as you can get to the real thing.
The innovative design of the Baja 5B includes a rigid 8mm (!) aluminum alloy chassis for extreme durability. The fully adjustable suspension uses four “Hyper Adjust Piston” externally adjustable aluminum shocks that have 5 dampening settings and can be adjusted without removing the shocks. A Viscous Torque Control differential delivers the power to the rear wheels smoothly and uses hardened metal throughout the drivetrain for reliable performance. Special 3-piece beadlock wheels are included, so no glue is used to mount the tires, which makes changing the sticky HPI Dirt Buster tires quick and easy.
The included TF-10 radio system is FM for excellent range and includes an adjustable failsafe system for extra protection. The steering servo is a massive 25 kg-cm unit for quick steering and lots of torque. Standard equipment includes a 2000mah 6 cell rechargeable receiver pack and an AC charger. The radio system is protected by a sealed housing with an external charging jack, and both servos are water resistant designs that allow the Baja 5B to be driven in extreme off-road conditions.
Power comes from a massive 23cc “Fuelie” gasoline engine with plenty of power to make the Baja 5B feel as quick and nimble as a 1/10 th scale buggy. The Baja 5B runs for more than 30 minutes on a single tank of gas, and refueling with gasoline costs a fraction of nitro hobby fuel. The Fuelie engine includes a pullstarter, primer, choke, kill switch and a high performance dual element foam air filter.
Look for the Baja 5B to be released before the end of the year, price and part numbers will be coming soon!
Elikkäs Hpi:n tuleva 1:5 buggy,aika cool!!!!!!!
« Vastaus #1 : 02.09.05 - klo: 20.07 »
Nyt mielenkiinto heräs, kun on isoista kyse.  :)
Poissa Esto_r
« Vastaus #2 : 02.09.05 - klo: 20.49 »
No johan on! Siis todella jännä/hieno!!!! :shock:
Hpi mt2 18ss
Poissa Joona H
« Vastaus #3 : 02.09.05 - klo: 21.18 »
Eipä ole viripilliä,harmi.
Piristävää nähdä,että alkaa tulla vähän ns."Marder-kaaviosta" poikkeavia 1:5 buggyja.
Poissa jeejee
« Vastaus #4 : 03.09.05 - klo: 07.24 »
Jänniä ratkaisuja, tulee yhen pelin sand rail mieleen.  :mrgreen: Aika oudosti menee kori tossa etuosassa ja naliveo ois yliveto.  :wink: Aika arat ovat noi etuiskarit vääntymään ja katolleen menee kunnolla. Putki runko ja normi runko yhdistetty kivast, melko erikoinen.
Poissa Jartsa
« Vastaus #5 : 03.09.05 - klo: 07.33 »
Lainaus käyttäjältä: "jeejee"
Samallaillahan nuo on kuin missä tähansa muussa "buggyssa" ja vielä kun ovat tukivarren "sisällä"
Ne  vaan näyttää heikolta kun ei ole jousia noissa kuvissa
Poissa jeejee
« Vastaus #6 : 03.09.05 - klo: 07.46 »
Mutta toi yläpään kiinnitys kun tulee katooleen vähän nokkapainotteisesti niin ainakin "väri" lähtee.
Poissa Dustbin
    • http://koti.mbnet.fi/dustbin/kuvat/
« Vastaus #7 : 03.09.05 - klo: 11.43 »
Aikamoinen alumötikkä jos runkolevytkin 8mm ainetta :mrgreen:
Kuvista päätellen näyttäisi aika menevältä ja myyvältä mallilta. Jos hinta ei hirveesti nouse FG autoista, niin varmasti tullaan suomessakin näkemään noita. Vielä kun saisi kuvat missä iskarit ja renkaat paikallaan niin näkisi auton todellisen luonteen..
XRAY T1FK'05 + SS8.5 PRO, HoBao Hyper 7 + V-spec
Poissa Joona H
« Vastaus #8 : 03.09.05 - klo: 19.35 »
Tuolla pari lisäkuvaa:
http://www.hpiracing.com/bb5/
Poissa HelpDesk
    • http://www.tha-dark.com
« Vastaus #9 : 03.09.05 - klo: 23.01 »
oho tuota autoa pidetään ku pikku lasta kädestä  :mrgreen:
Team Kyosho Sweden
www.kyosho.se Omat kotisivut: www.tha-dark.com
Poissa Joona H
« Vastaus #10 : 23.09.05 - klo: 19.00 »
http://www.rc411.com/forum/showthread.php?t=686  8)
Näyttää vielä hienommalta kuin ekoissa kuvissa!
« Vastaus #11 : 23.09.05 - klo: 19.02 »
on komeen näköinen vehje tossa ajokuvassa!
Poissa Divi
« Vastaus #12 : 23.09.05 - klo: 20.30 »
Mä ostan tuollasen...
heti ku voitan lotossa...
Poissa Joona H
« Vastaus #13 : 30.09.05 - klo: 17.44 »
Nyt olis jo videota jaossa:
http://s10.yousendit.com/d.aspx?id=33VKDGAOMBKUA1M42I5Q7L6LAK
Tosin sanoivat,että tuo linkki umpeutuu kuuden päivän sisällä,eli kannattaa ladata heti.Hpi:n sivuille ovat kuulemma piakkoin laittamassa videoita myös.
Äänet on ihan mukavat 8)
Poissa mikko93
« Vastaus #14 : 30.09.05 - klo: 18.24 »
Kulukee petroolilla... Enpä oo ennen kuullu tommosta ;)..
mitenkäs paljo petrooli muuten maksaa? tietääkö kukaan?
Poissa Divi
« Vastaus #15 : 30.09.05 - klo: 18.29 »
Hieno laite, on vain vähä uskon puutetta noihin takavetoihin ultiman jälkeen. takanakit kuluu alta kun ekan kerran käyt asvaltilla kääntymässä ja muutenkaan ei pääse suoraa... niin eikä niillä pääse minkäänlaisessa maastossa  :roll:
Poissa Mr.MR
« Vastaus #16 : 30.09.05 - klo: 18.33 »
Hmm.. "Petrol" ei ole ihan suoraan sama, kuin meidän Suomalaisten käsitys petroolista. Petrol = bensiini.  :mrgreen:
Poissa Mr.MR
« Vastaus #17 : 30.09.05 - klo: 18.40 »
Lainaus käyttäjältä: "Divi"
Nyt pitäis muistaa, että noissa isoissa autoissa on painoa aika paljon. Ja renkaissa aika paljon kuviota. Eli ne on helpompia ajaa takavetoisena, kuin pienemmät autot. Kyllä tolla FG:n Off-Road-Beetlelläkin pystyy vedättämään kaasulla pitkää sivuluisua, enkä ole vielä kohdannut ongelmia suoraan ajamisen kanssa. Voi sitten lisäksi asennella eteen jarrulevyjarrut, jos ei pidä käsijarrutyylisestä takajarrusta. Enkä olis heti uskonut millaisia hiekkamäkiä auto nousi ylös kosteassa hiekkamonttu hiekassa.
HPI on mielestäni kovasti tervetullut markkinoille. Hyvä että olisi kilpailijoita FG:lle, niin ei pääse hintojaan liikaa nostamaan. Paras on vaikea olla.  :wink:
Poissa Joona H
« Vastaus #18 : 04.10.05 - klo: 18.43 »
Täällä on pari uutta kuvastusta Bajasta.
Poissa Divi
« Vastaus #19 : 04.10.05 - klo: 18.57 »
oukka, eturangas on sitte savagen kumetsun kokoa... aika massiivinen auto olis hyllyyn  :wink:
Poissa Rahtimies
« Vastaus #20 : 04.10.05 - klo: 19.11 »
Todella realistisen näköinen laite,mieleen tulevat heti Baja 500 kilpurit.
Tuohan on kuin suurennettu Kyosho Scorpion :D .
Jos hinta on kilpailukykyinen niin voivat yleistyä mukavasti.
Ainakin itseäni alkoi kiinnostaa :D
« Vastaus #21 : 05.10.05 - klo: 14.43 »
Nuo etupään kiinnitykset ovat liian esillä. Tuolla kun vauhdista katolleen heittää niin lähtee koko etupää irti.
Siinä menee sit helposti iskaritkin solmuun ja näissä isoissa on sitä massaakin niin varmasti hajoaa helposti verrattuna 1/8 crosseihin.
Muutenhan auto näyttää menevältä  :)
« Vastaus #22 : 05.10.05 - klo: 14.52 »
turha verrata 1/8 krossiin, ne kun eivät hajoa  :mrgreen:
ei kai tuolla nyt olla selällään kovin usein
Poissa opa
« Vastaus #23 : 05.10.05 - klo: 15.24 »
Mitäs tämä hupi maksaa?
Smartech Thunderbolt 4x4, Kyosho Inferno GT,
X-Ray XT8 2009 Spec, XTM Rail, Hpi RS4 Micro, Kyosho Mini-Z
Poissa Kari
« Vastaus #24 : 05.10.05 - klo: 20.03 »
Poissa opa
« Vastaus #25 : 06.10.05 - klo: 20.19 »
Voishan toi enemmänkin olla. Ruåtsissa katselin jotain 1/6 monsteri-kuplia ja maksoivat euroissa n. 2000  :shock:
Poissa jeejee
« Vastaus #26 : 06.10.05 - klo: 20.47 »
Kruunua?
« Vastaus #27 : 06.10.05 - klo: 20.48 »
Ne Kuplat olivat todennäköisesti Fg.n autoja. Suomessa hinnat alle 1000e Rtr paketilla.
Poissa Teemus.
« Vastaus #28 : 06.10.05 - klo: 21.40 »
tossahan sanottiin "euroissa" !
ja jos se olis kruunuissa ni se olis vaan n.200 e
AE RC10T4 ja HBX 4WD Buggy
Poissa jeejee
« Vastaus #29 : 09.10.05 - klo: 08.22 »
http://www.hpiracing.com/movies/Baja_5B_Long.wmv Tossa on vähän pisempi video.
