Kirjoittaja Aihe: Xray polttis uutiset [XB8 2019 malli julkaistu]  (Luettu 66755 kertaa)
Poissa RacingFactory
« : 22.01.09 - klo: 17.56 »
« Viimeksi muokattu: 17.12.18 - klo: 15.13 kirjoittanut eurorc.com »
Vs: XRAY POLTTIS UUTISET
« Vastaus #1 : 22.01.09 - klo: 18.08 »
XB 808 malliin tullut tärkeä päivitys.
Alumiininen laakerinholkki diffilaakereille:
Tuotenro: 35 2075
« Vastaus #2 : 14.02.09 - klo: 01.25 »
XB808 009 Spec päivitykset:
2009 XRAY 808 New Specs:
• new ultra-low profile racing body, designed exclusively by XRAY
• new super-low profile foam air filter with redesigned rubber elbow
• new stronger, one-side steel-sealed diff ball-bearings
• new alu bearing collar reinforces diff bearing assemblies
• new reinforced composite front & rear bulkheads
• new larger capacity fuel tank with capacity-adjustment segments
• new fuel line holders mounted directly on fuel tank
• new fuel tank pressure cap with 1-piece profiled seal for perfect fitment
• new reinforced composite ball joints
• new protective rubber folding shock boots for big-bore shocks, front & rear
• new lower shock body mounting cap, grooved for folding shock boots
• new narrow lower shock ball joints, redesigned for folding shock boots
• new upgraded servo saver with O-ring for secure adjustment
• new longer rear shock body mount for more secure body mounting
« Vastaus #3 : 14.02.09 - klo: 01.29 »
Xray NT1 2009 päivitykset:
New 2009 NT1 Specs:
• included optional XRAY aluminum racing shock bodies
• included optional HUDY Spring Steel™ front & rear CVD driveshafts
• new wider 2-speed 2nd gear for increased durability & lifespan
• new reinforced & improved suspension parts
• new wider central drive belt for increased durability & lifespan
• new fuel tank pressure cap with 1-pc profiled seal for perfect fitment
• new steering servo mount for mid size servos
• new top deck mounts for mid size servos
• new belt tensioner holder for improved belt tension adjustment
• new updated radio plate
• new harder 2-speed springs
« Vastaus #4 : 14.02.09 - klo: 01.31 »
XRAY XT8 2009:
New 2009 XRAY XT8 Specs:
• improved chassis balance and weight distribution
• all-new threaded big bore shocks
• new chassis with improved weight balance and longer wheelbase
• new big-bore shock springs
• new rubber protective shock boots
• new ultra-lightweight HUDY Spring Steel™ drive shafts
• new ultra-lightweight HUDY Spring Steel™ central drive shaft outdrives
• new ultra-lightweight HUDY Spring Steel™ drive axles
• new front suspension geometry with adjustable upper camber link
• new graphite radio plate
• new graphite central diff upper plate
• new front & rear graphite shock towers
• new graphite front upper plate
• new graphite steering plate
• new front upper HUDY Spring Steel™ adjustable turnbuckles
• new longer engine mounts to reduce chassis bending
• hard clutch springs
« Vastaus #5 : 17.03.09 - klo: 22.39 »
HUDYn UUSI PITBAG:
Tätä löytyy suoraan hyllystä, netissäkin vielä tämän viikon aikana.
Täydellinen referaatti tuotteesta täällä:http://www.hudy.net/xhudy/news/newsdesc.php?news_id=89&kategoria=89&Hudy_Session=463d7c4c578330a550885f1abaa67dbc
« Vastaus #6 : 23.03.09 - klo: 11.48 »
XB808 Polttiskrossarin 009 Spec Päivityskitti
Paketti sisältää:
- 35 1330   XB808 COMPOSITE REAR BODY POST - LONG   1kpl
- 35 2002   XB808 DIFF BULKHEAD BLOCK SET FRONT/REAR - V2   2kpl
- 35 2075   XB808 ALU BEARING COLLAR FOR DIFF BEARINGS (2)   1kpl
- 35 2151   XB808 FRONT UPPER ARM BALL JOINT (2) - V2   2kpl
- 35 2501   XB808 SERVO SAVER COMPLETE SET - V2   1kpl   (only alu nut with o-ring)
- 35 2664   XB808 COMPOSITE STEERING BALL JOINT 6.8MM (2) - V2   1kpl
- 35 2665   XB808 COMPOSITE RELIEF STEERING BALL JOINT 6.8MM (2) - V2   1kpl
- 35 3131   XB808 REAR UPPER INNER CAMBER LINK BALL JOINT (2) - V2   1kpl
- 35 8016   COMPOSITE SHOCK BALL JOINT FOR SHOCK BOOT (2)   2kpl
- 35 8072   XB808 FOLDING SHOCK BOOT (4)   1kpl
- 35 8141   XB808 ALU SHOCK BODY NUT FOR SHOCK BOOT (2)   2kpl
- 35 8602   FUEL TANK 123CC - SET - V3   1kpl
- 35 8801   AIR FILTER SET - LOW PROFILE   1kpl
- 35 9704   XRAY XB808 BODY FOR 1/8 OFF ROAD BUGGY - LOW PROFILE   1kpl
- 94 1320   HIGH-SPEED BALL-BEARING 13x19x4 RUBBER & STEEL SEALED  (2)   1kpl
Kitin hinta: 99.90€
« Viimeksi muokattu: 01.04.09 - klo: 11.41 kirjoittanut RacingFactory »
« Vastaus #7 : 23.03.09 - klo: 12.14 »
Xray NT1 Polttisturistin 2009 Spec Päivityskitti:
Paketti sisältää:
30 8305   XRAY ALU SHOCK ABSORBER-SET 4-STEP (2)   2kpl
33 2110   COMPOSITE SUSPENSION ARM FRONT LOWER - V2   2kpl
33 2130   COMPOSITE SUSPENSION ARM FRONT UPPER - V2   2kpl
33 2210   COMPOSITE STEERING BLOCK RIGHT - V2   1kpl
33 2220   COMPOSITE STEERING BLOCK LEFT - V2   1kpl
33 3070   BELT TENSIONER SET - V2   1kpl   (only graphite part)
33 3110   COMPOSITE SUSPENSION ARM REAR LOWER - V2   2kpl
33 3310   COMPOSITE UPRIGHT REAR - V2   2kpl
33 5205   CVD DRIVE SHAFT - FRONT - SET - HUDY SPRING STEEL™ (1)   2kpl
33 5305   CVD DRIVE SHAFT - REAR - SET - HUDY SPRING STEEL™ (1)   2kpl
33 5441   PUR® REINFORCED DRIVE BELT SIDE 4.4 x 390 MM - V2   1kpl
33 5554   COMPOSITE 2-SPEED GEAR 54T (2nd) - V2   1klp
33 5581   SPRING C=7.8 FOR GEAR BOX - MEDIUM - SILVER  (2)   1kpl
33 6120   COMPOSITE STEERING SERVO HOLDER - SET - V2   1kpl   (only steering servo mount)
33 6230   COMPOSITE RADIO PLATE MOUNTS (L+R) - V2   1kpl
33 8601   FUEL TANK 75CC - SET - V2   1kpl
Kitin hinta: 149,90€
« Vastaus #8 : 25.03.09 - klo: 00.01 »
Uusi Xray XT8 2009' esittelyssä:
Uutta Xray XT8 Truggyssä mm:
  • Uudet BigBore iskarit
  • Uudet etulinkit
  • Uudet Super Lightweight vetoakselit ja kardaanit
  • Hiilikuituiset ylädekin osat
  • Uusi pitempi pohjalevy
  • Uusi polttoainetankki
  • Uudet pidemmät moottoripukit jne jne. yli 20 päivitettyä osaa!!
Uudet XT8 2009 autot tulossa Suomeen noin viikon kuluttua!
Hinta: 489€
« Vastaus #9 : 23.04.09 - klo: 23.37 »
« Vastaus #10 : 25.06.09 - klo: 00.34 »
Saimme tänään Xray tilauksen varastoon.
Tässä lähetyksessä mm.
- Xray 808
- Xray T2R Pro
- Xray X10
- Xray 1/18 RTR Monsteria...Hudy tuotteita jne...
Tilaus toimitettiin kisakiireiden takia suoraan Helsingin liikkeeseen.
« Vastaus #11 : 21.11.09 - klo: 23.10 »
XRAY 808 2010 JULKAISTU!
2010 XRAY XB808 New Specs:
• new longer, hard-anodized Swiss 7075 T6 aluminum chassis
• longer chassis results in increased stability and improved handling
• redesigned weight balance ensures improved jumping and rough track handling
• refined stability makes the car easier to drive
• wider rear chassis increases side-to-side stability
• new longer rear drive shaft
• new radio box position
• new front & rear diff bulkheads with Labyrinth Dust Covers™
• new front & rear diff cases with larger more durable 13x20 bearings
• new larger diff bearing collars
• new brake disks
• larger more durable front, middle & rear diff bearings
Aiheesta lisää XRAYn sivuilla: http://www.teamxray.com/teamxray/products/proddesc.php?prod_id=3346&Xnet_Session=182e680035abf0e919e5d4289f7bdeac
« Viimeksi muokattu: 21.11.09 - klo: 23.20 kirjoittanut RacingFactory »
« Vastaus #12 : 14.12.09 - klo: 21.40 »
XRAY XB 808 - 2010 SPEC
Varaa nyt omasi:
http://www.racingfactory.fi/tuotteet/POLTTOMOOTTORI-AUTOT-Xray/35005-XRAY-XB808-2010-Specs-108377
Toimitus Tammikuussa 2010.
-RF
« Vastaus #13 : 14.01.10 - klo: 13.35 »
XRAY XB 808 - 2010 SPEC ensi viikolla varastossa!
« Vastaus #14 : 05.03.10 - klo: 18.20 »
XRAY 808 2010 SPECS CONVERSION SET
• new brake disks
http://www.racingfactory.fi/tuotteet/XRAY-XRAY-XB808/350902-XRAY-XB808-2010-SPECS-CONVERSION-SET-108638
« Vastaus #15 : 21.07.10 - klo: 20.36 »
XRAY varaosalähetys saapunut ja tuotteet on päivitetty sivuillemme.
Laakereita ym löytyy jälleen suoraan varastosta.
Loppuviikosta tulee vielä toinen lähetys, sopivasti viikonlopun kilpailuun.
-RF-
« Vastaus #16 : 15.02.11 - klo: 22.45 »
XRAY julkaisi Nurnbergin messuilla "uuden" päivitetyn XB 808 2011 Spec auton.
Uusia osia on taas aikalailla:
• New chassis to accomodate all new drivetrain parts
• New and improved handling
• New suspension geometry with multi-adjustable roll centers
• New improved weight balance with more centrally-positioned rotary moment
• New diff bulkheads to accomodate new drivetrain parts
• New central drivetrain system
• New central CVD drive shafts
• New pinion gears
• New diff ball-bearings
• New better-sealing shock O–rings
• New rear brace to accomodate new central drive shafts
• New front and rear alu suspension holders with eccentric roll centers
• New composite eccentric bushings
• New more robust suspension pins
• New high-downforce body
• New graphite radio plate more securely placed between throttle servo and spur gear
• New updated radio box
Ensimmäinen erä uusia 808 2011 Spec autoja saapuu meidän varastoon 2-3 viikon sisällä.
Mikäli haluat olla ensimmäisten joukossa, ota yhteyttä joko puhelimella tai sähköpostilla.
Lisäämme auton piakkoin myös verkkokauppaamme.
t.RF
« Vastaus #18 : 11.04.11 - klo: 18.11 »
XRAY XB808 - 2011 Specs autoja saapunut.
Tästä erästä melkein kaikki autot myyty ennakkoon. Varastossa 1 auto.
http://www.racingfactory.fi/tuotteet/POLTTOMOOTTORI-AUTOT-Xray/XRAY-XB808-2011-Specs-109018
t. RF
« Vastaus #19 : 13.04.11 - klo: 18.31 »
Kevään ensimmäinen varaosatilaus on saapunut.
Lähetyksessä runsaasti uusia 808n tuotteita:
352314 COMPOSITE SQUARE ADJ. ROLL-CENTER BUSHINGS (2)
353357 XB808 ALU ADJUSTABLE REAR HUB CARRIER - SWISS 7075 T6 - HARD COATED
355424 XB808'11 FRONT CENTRAL CVD DRIVE SHAFT - HUDY SPRING STEEL™
356002 XB808'11 RADIO CASE SET
359706 XRAY XB808'11 BODY - FRONT DOWNFORCE
971034 SILICONE O-RING 3.4x2 (10)
http://www.racingfactory.fi/shop/cat/uusimmat_tuotteet.php
t. RF
« Vastaus #20 : 19.05.11 - klo: 18.40 »
« Vastaus #21 : 09.06.11 - klo: 18.05 »
Xray lähetys saapunut.
- XB808 2011 taas varstossa (ennakkotilatut autot lähetetty tänään)
- XB808 2011 Conversion kit vihdoin saatavilla
- XB808 ja NT1 varaosia saapunut
350903 XRAY XB808 - 2011 SPECS CONVERSION SET
http://www.racingfactory.fi/tuotteet/XRAY-XRAY-XB808/350903-XRAY-XB808-2011-SPECS-CONVERSION-SET-109183
Lähetyksessä seuraavat XB808 osat:
351104 XB808'11 ALU CHASSIS 3.0MM - HARDCOATED SWISS 7075 T6
352004 XB808'11 DIFF BULKHEAD BLOCK SET FRONT/REAR
352092 XB808 GRAPHITE FRONT SHOCK TOWER - CNC MACHINED 4 MM
352151 XB808 FRONT UPPER ARM BALL JOINT - V2 (2)
353092 XB808 GRAPHITE REAR SHOCK TOWER - CNC MACHINED 3.5 MM
353486 XB808 REAR ANTI-ROLL BAR 2.6MM
355130 ACTIVE DIFF STEEL BEVEL & SATELLITE GEARS (2+4)
355238 XB808 CVD DRIVE SHAFT COUPLING THREADED
355421 XB808 FRONT CENTRAL CVD DRIVE SHAFT - HUDY SPRING STEEL
355622 XB808 REAR CENTRAL CVD DRIVE SHAFT 133MM - HUDY SPRING STEEL
356001 XB808 RADIO CASE SET
356111 XB808 GRAPHITE RADIO PLATE
356117 XB808'11 GRAPHITE RADIO PLATE
356200 BRAKE/THROTTLE ARMS & STEERING SERVO ARMS - SET
357212 LOWER INNER PIVOT PIN F+R EUROS'05 TQ (2)
358082 XB808 SHOCK RUBBER MEMBRANE (4)
358168 XT8/XB808 FRONT SHOCK SHAFT (2)
358261 XB808 REAR SHOCK SHAFT (2)
358526 XB808 CLUTCH BELL 16T WITH OVERSIZED BALL-BEARINGS - V2
358531 FLYWHEEL
358540 FLYWHEEL COLLAR
359100 MOUNTING HARDWARE PACKAGE FOR XB8 - SET OF 150 PCS
Lähetyksessä seuraavat NT1 osat:
332110 COMPOSITE SUSPENSION ARM FRONT LOWER - V2 3
332130 COMPOSITE SUSPENSION ARM FRONT UPPER - V2
332210 COMPOSITE STEERING BLOCK RIGHT - V2
332220 COMPOSITE STEERING BLOCK LEFT - V2
335050 REAR GEAR DIFFERENTIAL - SET
335060 COMPOSITE REAR DIFF. CASE & COVER
335430 PUR REINFORCED DRIVE BELT FRONT 5.0 x 186 MM - V2
335441 PUR REINFORCED DRIVE BELT SIDE 4.5 x 396 MM - V2
335450 PUR REINFORCED DRIVE BELT REAR 5.5 x 177 MM - V2
337310 REAR LOWER INNER PIVOT PIN (2)
338183 SPRING-SET D=1.7 (28.5 LB) DARK-BLUE - SOFT-MED - FRONT (2)
338582 CLUTCH SPRING - HARD
XRAY XB9
« Vastaus #22 : 14.12.11 - klo: 17.11 »
XRAY XB9 - First details
• All-new XB9 platform
• Innovative XRAY Multi-Flex™ setting
• All-new and improved weight balance and weight distribution
• Easy chassis flex setting for traction and stability adjustment
• More forgiving and easy-to-control handling
• Long-term tested by team and regular drivers in all standard conditions
• Focus on smallest details to increase performance, handling, and reliability
• All-new shocks with completely redesigned parts were long-term tested at tracks and using special simulation equipment for extreme overload
• New drivetrain parts for increased performance, weight balance, traction, and reliability
More details coming soon....
« Vastaus #23 : 09.01.12 - klo: 13.37 »
XRAY XB9 - All Details Revealed
Lisää XB9 tietoa:
http://goo.gl/9K4BB
Ensimmäiset autot näillä näkymin helmikuun alussa!
« Vastaus #24 : 17.02.12 - klo: 18.02 »
Uusi XRAY XB9 - Nyt ennakkotilattavissa!
Ensimmäinen pieni erä uusia XB9 autoja saapuu ensi viikon lopussa.
Autoa voi nyt ennakkotilata.
Enemmän autoja tulee toisesta tuotantoerästä maaliskuussa.
Kauden alku XRAY XB9 autolla on ollut hyvä! Montpellier GP:ssä viime viikonloppuna TQ ja lopputuloksissa 2 ja 3 sija!
XRAY XB9
« Vastaus #25 : 23.02.12 - klo: 17.32 »
XRAY XB9 - Nyt Suomessa!
Ennakkoon tilatut autot lähetetty tänään.
XRAY XB9
« Viimeksi muokattu: 24.02.12 - klo: 16.11 kirjoittanut RacingFactory »
XRAY NT1 - 2012 SPECS & RX8 - 2012 SPECS
« Vastaus #26 : 15.03.12 - klo: 17.28 »
Uusia XRAY ratapolttisautoja!
XRAY RX8 - 2012 SPECS
Seuraava erä XB9 autoja saapuu ensi viikolla.
Autoja lähetetään ennakkotilaajille heti kun saapuu.
« Vastaus #27 : 21.03.12 - klo: 17.53 »
Toinen loppuun myyty erä XB9 autoja saapunut.
Autoja lähetetty. Lisää autoja 2-3 viikon kuluttua.
XRAY XB9
Samassa lähetyksessä myös XB9 / XB808 osia, mm uusia jousia:
358174 XRAY FRONT SPRING SET PROGRESSIVE C=0.7-0.8 (2)
358274 XRAY REAR SPRING SET PROGRESSIVE C=0.5-0.6 (2)
« Vastaus #28 : 10.04.12 - klo: 18.50 »
XRAY XB9
« Vastaus #29 : 08.05.12 - klo: 17.05 »
Seuraava erä XB9 autoja saapuu tällä viikolla.
Tilattavissa:
XRAY XB9
