The engineers in Area 51 have once again evolved the B44 to keep it a winner, while everyone else is just trying to keep up. If you're ready to step up your 4WD program, the B44.2 is ready for you!
Factory Team 12mm 'Big Bore' hard anodized aluminum threaded shocks with TiN "Gold" 3mm shock shafts
· Updated 2.5mm carbon-fiber chassis +8mm optimized for LiPo saddle packs
· VTS slipper (variable torque, multi-plate slipper with 3 drive surfaces) assembly featuring a high-rate spring
· Composite battery trays allow for battery position adjustment with integrated spacers and quick-change battery straps
· Updated 3.5mm front shock tower and 3.0mm rear shock tower designed specifically for the new 12mm shocks
· Factory Team 12mm aluminum rear clamping hexes and rear hex wheels
· Updated front top deck for increased rigidity featuring locking antenna mount
· Factory Team 7075-T6 blue aluminum 0° rear hubs with oversized outer bearing
· Updated front suspension arm for increased durability
· Blue aluminum cam-type motor mount for easier and more secure gear mesh adjustments
· JConcepts Finnisher +8mm body (clear) and Factory Team protective chassis tape included
