Kirjoittaja Aihe: Tamiya TRF417/TRF417X/TRF417 V5  (Luettu 37133 kertaa)
Poissa RacingFactory
  • Aluevalvoja
    • www.racingfactory.fi
racingfactory.fi Avoinna 24/7
  • Aluevalvoja
Vs: Tamiya TRF417/TRF417X
« Vastaus #31 : 07.10.11 - klo: 12.37 »
42205 TRF417X
Tamiya Racing Factory (TRF) team's ace driver Marc Rheinard won the 2010 IFMAR World Championship with the TRF416X. In December of the same year, the TRF417 was released and it has achieved equally impressive results at various top-level international R/C races. With an eye on winning the upcoming 2012 IFMAR World Championship, Tamiya is introducing this latest iteration of the TRF417, the TRF417X. Although the differences between the new car and the TRF417 may seem subtle, the newly-designed lower deck offers improved chassis flexibility for better low-speed traction. The previous one-piece motor mount has been replaced by a three-piece type to allow further adjustment of chassis' flexibility by linking them together. The thickness of the front and rear damper stays have been increased to 3.5mm and other new developments include a new upper deck, metal battery holders which serve as counterweights, and low-height kingpins. A front direct coupling and rear gear diff unit (Item 42197 TRF417 Gear Differential Unit II) are also included.
Motor mount allows adjustment of chassis rigidity and new positions of motor attachment holes enable a wider choice of gear ratios to better suit your track or racing class.
Damper stays have damper attachment slots to allow fine setting adjustment. Increased thickness of 3.5mm offers improved damper attachment rigidity for greater damper effectiveness.
  • Aluevalvoja
  • Aluevalvoja
« Vastaus #33 : 31.10.11 - klo: 19.05 »
TRF417 Gear Diff Unit II huoltosarja nyt varastossa:
51470 Maintenance Parts Set for Gear Differential Unit Cup Joint
Samalla saapui lisää muita ratasdiffin osia:
51460 TA06 Gear Differential Unit Bevel Gear Set
51464 TA06 Gear Differential Unit Gasket (4pcs.)
51469 TRF417 Gear Diff Unit II Cup Joint (Right & Left)
  • Aluevalvoja
« Vastaus #34 : 21.11.11 - klo: 18.49 »
Tamiya TRF417X on saapunut.
Jälleen kerran suomalaiset asiakkaat saivat uuden TRF auton ensimmäisenä maailmassa!  :afro:
Kaikki tämän ensimmäisen lähetyksen autot olivat ennakkoon tilattuja ja autoja on tänään lähetetty.
Päivitämme kun tiedämme milloin saamme lisää autoja (tod.näk. joulukuussa).
42205 Tamiya TRF417X Chassis Kit
  • Aluevalvoja
« Vastaus #35 : 29.11.11 - klo: 17.37 »
  • Aluevalvoja
« Vastaus #36 : 29.11.11 - klo: 17.38 »
  • Aluevalvoja
« Vastaus #37 : 04.01.12 - klo: 18.27 »
Lisää TRF417X autoja saapuu vihdoin noin viikon kuluttua.
Enakkotilauksia voi tehdä;
Tamiya tiimi on tänä vuonna TSM-10 luokassa todella vahva. Hallitseva mestari Matias Kuusinen jatkaa Tamiyalla samoin kuin 2011 SM3 Kalle Lehto. Lisäksi SM4 Miko Teponoja, Ari Heinonen, Henry Salmén ja Tomi Mairue ajavat kaikki TRF417:lla!
  • Aluevalvoja
« Vastaus #38 : 12.01.12 - klo: 13.09 »
TRF417X autolähetys saapunut.
Ennakkon tilatut autot lähetetään tänään.
  • Aluevalvoja
« Vastaus #39 : 16.01.12 - klo: 20.35 »
FinTrack Tour I 2012 14.-15.1.2012 Kuusankoski
TSM-10 SM I
2. Matias Kuusinen - TRF417X
3. Miko Teponoja - TRF417X
4. Henry Salmén - TRF417X
5. Kalle Lehto - TRF417X
11. Ari Heinonen - Tamiya
12. Tomi Mairue - Tamiya
13. Jukka Penttinen - Tamiya
14. Kenneth Södergård - Tamiya
15. Jörg Tiit - Tamiya
22. Juha Menna - Tamiya
TSS-10 FTT I 2012
3. Marko Jussila - Tamiya
  • Aluevalvoja
« Vastaus #40 : 27.01.12 - klo: 16.25 »
Vahvaan Tamiya TRF417X tiimiin on liittymässä lisää kuskeja  :wink:
Lisää autoja saapuu noin viikon päästä.
Nyt ennakkotilattavissa:
  • Aluevalvoja
« Vastaus #41 : 07.02.12 - klo: 13.10 »
Tamiya TRF417X nyt varastossa.
  • Aluevalvoja
« Vastaus #42 : 09.02.12 - klo: 17.14 »
Nyt varastossa:
4004089 TRF417X Lower Deck
4004090 TRF417X Upper Deck
4004082 TRF417 Upper Deck
http://www.racingfactory.fi/tuotteet/TAMIYA-Tamiya-TRF415TRF416TRF417
  • Aluevalvoja
« Vastaus #43 : 27.02.12 - klo: 18.30 »
FinTrack Tour II 2012 25.-26.2.2012 Kiiminki
TSM-10 SM II
3. Matias Kuusinen - TRF417X
4. Ari Heinonen - TRF417X
6. Miko Teponoja - TRF417X
8. Henry Salmén - TRF417X
9. Kalle Lehto - TRF417X
  • Aluevalvoja
« Vastaus #44 : 27.03.12 - klo: 20.10 »
Tamiyan uudet TRF tuplanivelvetarit nyt varastossa.
42216 44mm Double Cardan Joint Shaft (2pcs.)
42221 Cross Joint For Double Cardan Joint Shaft (4pcs.)
Samassa lähetyksessä saapui myös TRF417X pohjalevyä ja ylädekkiä + paljon muita TRF417 osia.
  • Aluevalvoja
« Vastaus #45 : 16.04.12 - klo: 18.16 »
FinTrack Tour III 2012 14-15.4.2012 Laukaa
Tamiya TRF417X tuplavoitto SM III kisassa!
Madelle paalupaikka + voitto. Onnittelut!
TSM-10 SM III
1. Matias Kuusinen - TRF417X
2. Miko Teponoja - TRF417X
4. Kalle Lehto - TRF417X
6. Henry Salmén - TRF417X
  • Aluevalvoja
« Vastaus #46 : 07.05.12 - klo: 17.11 »
TRF 5x10x3mm laakerit TRF tuplanivelvetarille.
42220 1050 Ball Bearing (3mm Thick, 2pcs.)
  • Aluevalvoja
« Vastaus #47 : 28.05.12 - klo: 18.57 »
FinTrack Tour IV 2012 26.5.2012 Kouvola
TSM-10 SM IV
TQ + 5. Kalle Lehto - TRF417X
8. Kenneth Södergård - TRF417X
9. Toni Niinivirta - TRF417X
TSS-10 SM IV
3. Tino Eriksson - TRF417X
« Viimeksi muokattu: 28.05.12 - klo: 19.05 kirjoittanut RacingFactory »
  • Aluevalvoja
« Vastaus #48 : 11.06.12 - klo: 18.24 »
FinTrack Tour V 2012 9.6.2012 Laukaa
TSM-10 SM IV
1. Miko Teponoja - TRF417X
7. Kalle Lehto - TRF417X
TSS-10 SM IV
2. Tino Eriksson - TRF417X
Onnittelut Mikolle hienosta voitosta ja Matiakselle ja Tinolle podium sijoituksista!
  • Aluevalvoja
TRF417 V5 Ennakkotilaus
« Vastaus #50 : 11.09.12 - klo: 15.26 »
Uusi TRF417 V5 tulossa.
TRF417 V5 = 2012 IFMAR ISTC Maailmanmestariauto.
Tarkat specsit varmistuu vasta myöhemmin mutta autossa ainakin nämä päivitykset verrattuna TRF417X autoon:
- uusi pohjalevy
- uusi ylädekki
- uusi "one-piece" servopidike
- uudet "aeration" iskarit
Kaikki nämä osat oli tehdaskuskeilla käytössä MM:ssä.
Ennakkotilaa nyt oma TRF417 V5.
Hinta ja toimitusaika varmistuu vasta kun autot ovat saapumassa, mutta hyvä arvio on että autot saapuu marras-joulukuun vaihteessa ja hinta on noin sama kuin viime vuoden autossa (TRF417X). Autot toimitetaan tilausjärjestyksessä. Varmista nyt että saat auton ensimmäisestä erästä. Ennakkotilaukset info@racingfactory.fi
« Viimeksi muokattu: 03.10.12 - klo: 21.15 kirjoittanut RacingFactory »
  • Aluevalvoja
Vs: Tamiya TRF417/TRF417X/TRF417WX
« Vastaus #51 : 03.10.12 - klo: 18.09 »
  • Aluevalvoja
« Vastaus #52 : 03.10.12 - klo: 18.19 »
Voit nyt ennakkotilata uusi TRF417 V5 Premium Package Chassis Kit suoraan nettikaupassa.
Ensimmäisessä erässä aina rajoitetusti autoja; tästä erästä vielä pari autoa vapaana.
Eli jos haluat maailmanmestariauton heti kun tulee markkinoille niin kannattaa tehdä ennakkotilaus nyt!
Uudet TRF autot ovat norm. saapunut marraskuun lopussa. Tarkka toimitusaikataulu vahvistuu vasta kun lähtevät tehtaalta.
Jos olet jo tilannut auton sähköpostitse tai puhelimitse olet jo ennakkotilauslistassa, eli ei tarvi uudelleen tilata!
42240 TRF417 V5 Premium Package Chassis Kit - ENNAKKOTILAUS
« Viimeksi muokattu: 03.10.12 - klo: 21.17 kirjoittanut RacingFactory »
  • Aluevalvoja
« Vastaus #53 : 11.10.12 - klo: 17.19 »
  • Aluevalvoja
« Vastaus #54 : 16.11.12 - klo: 16.26 »
« Viimeksi muokattu: 16.11.12 - klo: 16.32 kirjoittanut RacingFactory »
  • Aluevalvoja
Vs: Tamiya TRF417/TRF417X/TRF417 V5
« Vastaus #55 : 28.11.12 - klo: 17.29 »
TRF417 V5 - Premium Package Chassis Kit on saapunut.
  • Aluevalvoja
Vs: TRF417 V5 Ennakkotilaus
« Vastaus #56 : 30.11.12 - klo: 17.18 »
Viimeiset TRF417 V5 Premium Package Chassis Kit autot saapuneet ja lähetetty eteenpäin tänään.
Yksi auto jäi varastoon.
Jos haluat itsellesi 2012 MM-voittajauton näin ennen kiskauden alkua, tee tilaus nyt:
Samalla saapui TRF417 autoon pari uutta osaa:
54425 Steel Cup Joint (L/R) for TRF417 Gear Differential Unit II
54428 Steel Bevel Gears for TA06 Gear Differential Unit
  • Aluevalvoja
« Vastaus #57 : 05.12.12 - klo: 16.55 »
Tamiya varaosalähetys saapunut.
Uusi vakaajasarja TRF417 autoon nyt varastossa:
54309 TA06 Stabilizer Set (F&R)
  • Aluevalvoja
« Vastaus #58 : 10.12.12 - klo: 18.36 »
FinTrack Tour I 2012-2013 Vantaa
TSS-10
2. Timo Hilpi - Tamiya
3. Sauli Lehtimäki - Tamiya
7. Tino Eriksson - Tamiya
TSM-10
10.Teemu Rytsy - Tamiya
  • Aluevalvoja
« Vastaus #59 : 04.01.13 - klo: 16.33 »
Tamiya lähetys saapunut.
Lähetyksessä uuden TRF417 V5 auton osia:
1424473 TRF417 V5 Logo Stickers
3404011 TRF417 V5 Lower Deck 2.25mm
3404012 TRF417 V5 Upper Deck 2.0mm
3404013 TRF417 V5 Front Damper Stay (3.5mm)
3404014 TRF417 V5 Rear Damper Stay (3.5mm)
3454880 TRF417 V5 Servo Mount
9224034 TRF417 V5 Swing Shaft Cap (White)
9804679 TRF417 V5 Diff Joint (Long/Short)
