RC10.FI
Mainostajat => FUTURE-RC FINLAND => Aiheen aloitti: Future-RC - 30.11.12 - klo: 14.31
Mugenin uusi Crossiauto! Ensimmäinen erä saapuu Tammikuun lopulla, varaa omasi nyt!
Tässä auton tekniset tiedot:
+ Width------------309mm
+ Wheel Base-----315-320mm adjustable
+ Gear Ratio---------11.98:1
+ Weight-------------3,370g
+ 3mm A7075 hard-anodized chassis
+ Lightweight spur and conical gears
+ Re-designed F/R upper & lower suspension arms and uprights
+ 15mm hard-anodized threaded shock with optimized geometry
+ Shorten front shock body with re-designed F/R shock boots
+ 5mm A7075 aluminum front shock tower with optimized geometry & 4mm A7075 aluminum rear shock towers
+ 5mm A7075 aluminum suspension mounts for optimized geometry
+ Improved brake system (new brake cam F/R & linkage and brake disc)
+ Relocated molded composite receiver box & low-CG battery holder
+ Re-designed fuel tank with fuel pickup system & quick pull cap
+ E0710 H.D. aluminum clutch shoes
+ Optimized steering geometry (New servo saver & steering plate & upright arm)
+ Aerodynamically enhanced performance body
+ High down force wing & mount with slider system for more or less down force
