"The X – 6 Sq. continues our adjustable height transmission. This allows you to adjust the height of the point of contact between the dogbones and the outdrives. In theory, raising this point of contact gives more forward bite and less side bite. Lowering the point of contact does the opposite: more side bite and less forward.
We are changing the angle of the dogbone in the outdrive. If you keep the ride height the same, changing the height of the outdrives changes the angle of the dogbones. On a conventional buggy, rear ride height changes are done to affect dogbone angle, and front ride height is adjusted secondly to compensate for the rear.
The New Math allows you to set dogbone angle and ride height independently. The Team usually sets transmission height first, then adjusts the remainder of the car, with front and rear ride heights based on the remainder of the set-up rather than dogbone angle considerations."
