Tässä kohtaa ensimmäinen kysymys on että olekko kalibroinut nopeussäätimen? Ohjetta Novetech:n sivulta:
(pitäs kyllä tulla ohjekirja mukanakin)
1.Auto –Esc default set at Auto, support transmitter with 50-50 or 70-30 throttle.
2.Manual- Adjust the throttle of transmitter to the factory default setting, insert
the set-up card & press “ manual” button. Plug the servo wire back into receiver.
Turn on the ESC, sound of “Bi Bi” comes out. Move the throttle to the forward
full, stay 2 second & get a sound of “Bi Bi”. Move the throttle to the reverse full,
stay 2 second & get a sound of “Bi Bi”. Release the throttle to the central point,
stay 2 second, & get a sound of “Do Re Mi”. The manual set up of the ESC
neutral is now completed. Be sure to strictly follow the set up steps at the
sequence of forward full, reverse full & then neutral. Otherwise the manual set
up can’t work properly.
3.Once after press down the manual button, the set-up process should be
completed within 15 sec, otherwise, the ESC will be reset to the auto-neutral
detecting.
