RC10.FI
Yleiset => Polttisautot => Mugen => Aiheen aloitti: JoukoH - 09.09.14 - klo: 14.17
Mugen on julkaissut uuden polttiskrossarin MBX7R
Tärkeimmät uudistukset.
MBX7R Features:
- 3mm A7075 hard anodized chassis
- Lightweight 46T spur gear
- Lightweight conical gears
- Straight cut conical and ring differential gears
- Specially designed front upper and rear lower suspension arms, front hub carriers,
rear suspension arms and hub carriers
- Fully adjustable steering with new geometry, servo saver and ackerman plate
- Front/Rear 16mm hard anodized threaded shocks with 3.5mm shock shafts and slim rubber
boots
- 5mm A7075 aluminum front shock tower
- 4mm A7075 aluminum rear shock tower
- 5mm A7075 aluminum lower suspension mounts for optimized geometry
- Special designed fuel tank with new baffle system
- E0710 heavy duty aluminum clutch shoes
- Stylish cab forward body
- Re-designed wing mount and high-down force wing
Lisätietoja
http://www.mugenseiki.co.jp/mugen/spec-mbx-7r_e.htm (http://www.mugenseiki.co.jp/mugen/spec-mbx-7r_e.htm)
http://www.redrc.net/2014/09/mugen-mbx7r-18th-nitro-off-road-buggy/#more-85911 (http://www.redrc.net/2014/09/mugen-mbx7r-18th-nitro-off-road-buggy/#more-85911)
http://www.neobuggy.net/2014/09/09/mugen-seiki-announce-mbx7r-buggy/#more-48178 (http://www.neobuggy.net/2014/09/09/mugen-seiki-announce-mbx7r-buggy/#more-48178)
Ei mullistavia muutoksia vanhaan,mutta se oli odotettavissakin.
Takaiskaritornin kiinnitykseen olisivat saanut keksiä jonkun vahvennuksen,taitaa olla muugenin ainut heikko kohta :roll:
