Oho... viikon saldo. Pitää näemmä alkaa jarrutella hieman...
Traxxas Stampede 4x4 rullaava
XTM Rail Brushless Buggy 1/8 4WD RTR
Futaba Megatech 2.4G + 2 x vastarit
1/8 Buggy Block Tyre - Pre Mounted On 17mm Hex Buggy Wheels
Tyre-Sand Paddle w/Insert(Pk2) Rail
1/8 Pro-5 Buggy Wheel Black/Chrm (4)
XK4074-2000KV Brushless Inrunner
S3660-2670 Brushless Inrunner (2670kv)
Turnigy TrackStar 4068 2560KV 1/8th Brushless Motor
2x Turnigy nano-tech 5000mah 3S 35~70C Lipo
2x ZIPPY Flightmax 5800mAh 4S1P 30C
Traxxas 3350X Velineon 3500kv Brushless Motor & VXL-3S ESC
Castle Creations 1410 Brushless Motor - 3800kV
Tekin Pro 4 Brushless Motor 3300kv (5mm Shaft)
2x Tense Front Wheel Rustler/Stampede Black W/Cap
2x Rulux 2.8 E-Stampede/Rustler 2wd/4x4 F & R Wheel
28T Steel 48P Pinion Gear 5mm
30T Steel 48P Pinion Gear 5mm
32T Steel 48P Pinion Gear 5mm
34T Steel 48P Pinion Gear 5mm
Plasti Dip Spray 325 ml Musta
Plasti Dip Sininen 429 ml
Infrapuna lämpömittari VS900
3x 4mm Gold Connectors 10 pairs (20pc)
3x HXT 4mm Gold Connector w/ Protector (10pcs/set)
3x Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
3x Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
2x Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
2x Turnigy 10mm Heat Shrink Tube - BLACK (1mtr)
2x Turnigy 2mm Heat Shrink Tube - BLACK (1mtr)
