Eli jos on esim: 3-port kone ja 11-port kone, niin mikä niiden ero on?
Toisessa ilmeisesti enemmän vääntöä ja toisessa kierroksia, mutta
kuinka päin?
Saman valmistajan esim. offroad koneissa porttien määrä voi päätellä jo jotaini.
Mutta ei pidä valmistajarajojen yli vertailla porttien määriä.
- Hount
Tästäpä syntyikin taas lisää kysyttävää...
Eli oon täs kattellu Sirion koneita (eikös ne oo huippuja?)
ja löytyi pelkästään "monsteri" kokoja näin paljo:
Sirio .30 Roto Start ENGINE3 port engineFEATURES: Blue colored anodized aluminum heatsink head
Pilot shaft crankshaft
Backplate for drop-in use with rotostart system
Rear round-port exhaust
Uses stock clutch system
Slide valve carburetor
ABC construction-Aluminum piston with a Brass liner that is Chrome plated
Trinity Sirio .27 Standard pullstartFEATURES: Pilot shaft style crankshaft, Large crankcase cooling fins
Round exhaust port, "Monster Big Block" and Sirio logo on top of the head,
Slide valve carburetor, ABC construction,
3 PORT ENGINE, Sealed front bearing,
Pull start engine Round exhaust port, "Monster Big Block" and Sirio logo
on top of the head, Slide valve carburetor, ABC construction, 3 Port engine,
Sealed front bearing, Pull start engine
Trinity Sirio .27 Standard 27XL (sama kuin edellinen???)
Mind blowing specs: 2.9 HP @ 39,000 RPM.
.27 c.i. / 4.42cc
4 portAluminum slide carburetor
Pull-start (installed)
Rear exhaust
SG crank
Both standard and turbo high performance head buttons included
Greyish blue anodized cylinder head with natural finish crankcase.
Carbon fiber slide valve carburetor
Trinity Sirio .27 PRO 7 port non pullFEATURES: Pilot shaft style crankshaft, Large crankcase cooling fins,
Round exhaust port, Slide valve carburetor, ABC construction,
7 Portengine, Sealed front bearing
Trinity Sirio .27 RACER Engine"...the highest horsepower per cubic inch of any engine we've ever tested" RC Nitro Magazine
The Sirio Racer motor has
11 ports (Most engines have around 4-6!),
39,000 RPM's, and over 3 horse power. Trinity claims 3.1. Some dyno
tests have proven this motor, when running slightly lean to produce just
shy of 4 horse power!
Kummallisinta on että Sirion sivuilta ei löydy tota 11 porttista???
Löytyy mallit:S30, S27s, S27r ja S27pro joista r ja pro mallissa
erona ilmeisesti vaan se että r mallissa on narustartti :shock:
Ilmeisesti siis päädyn tohon S27r malliin koska LST:ssä ei oo mahdollisuutta
käyttää starttiboxia ja S30 on liian iso, mutta sopiskohan sen rototakalevy
tohon S27r malliin narun tilalle??? 8)
