Ei ole paljon keskustelua tästä noparista, joten laitetaan tietoa julki.
Pakkauksen mukana tulee hyvät ohjeet, tuuletin, muutama ruuvi, nippusiteitä ja erittäin jämäkkää kaksipuolista teippiä.
Kotisivut Simppelit ohjeet Täydellisemmät ohjeet HAVOC PRO SC BRUSHLESS ESC FEATURES-Novak's Dynamic Timing Advance™ increases the motor's RPM dynamically through the throttle band for higher speeds—eight on-board adjustments from 15° to 42°.
-Multiple adjustable parameters via on-board programming: Minimum Brake (0-30%), Drag Brake (0-30%), Minimum Drive (0-15%), Timing Level (0-42°), Timing Set Point (19,500-4,000), Dead Band (2-8%), Throttle Curve (Linear/Expo), Brake Curve (Linear/Expo), Brake Frequency (1.67-13.7 KHz), Brake End Point (10-100%), Drive Frequency (16-7 KHz), Reverse, Motor Rotation, --Voltage Cut-Off, Hall Sensor Test
-Approved for ROAR Sportsman Class Racing
-On-board Hall Sensor Test to easily and quickly verify that the motor's sensors are working properly
-NovaBrakes™ provide instantaneous braking under any timing condition
-Sensor-based for excellent torque and low-speed driveability
-User friendly One-Touch programming interface with five colored status LEDs to help personalize the speed control’s settings
-Compatible with the entire 540 and 550-sized Novak brushless motor lines
-Robust 3-amp BEC for strong and fast steering response under any condition
-Highly water-resistant case
-Cross-cut ESC heat sink for reduced weight and efficient cooling
-Meets RoHS compliance and includes 120-Day Warranty
-Designed, assembled and tested by Novak in Irvine, Calif., using globally sourced components
HAVOC PRO SC BRUSHLESS ESC SPECS
-Input Voltage: 2S Li-Po cells, 2S Li-Fe cells or 4-6 Ni-MH cells (1.2V/cell)
-ESC Footprint: 1.16” x 1.47” (29.5 x 37.3 mm)
-Weight (without wires): 1.29 oz. (36.6 g)
-Design: Sensor-based
-Motor Limit: All 3.5-turn (540-sized) and all 4.5-turn (550-sized) sensored brushless motors
-On-Resistance (brushless): 0.00040 ohms @ 25°C trans. temp.
-BEC: 6.0 volts DC / 3.0 amps
-Status LEDs: 5
-Power Wires: 14G Super-Flex Copper-Strand Silicone Wire
HUOM!Ensimmäisissä havoc pro sc nopareissa on ilmennyt "brain board" ongelma softassa. Ilmenee pakkia käyttäessä --> ei kontrollia, eli on pakki täysillä heti. Tähän ongelmaan auttaa sähköposti tech@teamnovak.com osoitteeseen ja syötä seuraavat tiedot:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim?
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
Itselläni ilmenee tällä hetkellä senlainen ongelma edellämainitun lisäksi, että kaasukäyrän ollessa "expo" asennossa, ilmenee pientä rykimistä yläkierroksilla. Toivotaan, että piirilevyn vaihdolla paranee. Piti opetella ajamaan "linear" kaasukäyrällä ja oppi silläkin ajamaan :)
Olisi voinut myös lähettää nopari Novakille, mutta voi myös pyytää lähettämään piirikortin jos haluaa itse sen vaihtaa. Noparin kuoret ovat neljällä ruuvilla kiinni ja piirikortti on kädessä. Kyselin miten takuun laita, jos itse avaa noparin, mutta sanoivat että piirikortin saa vaihtaa. Piirikortti tuli noin viikossa laatikkoon.
Nyt odotellaan innolla, jos posti ehtii toimittaa .050"(1,27mm) avaimen tällä viikolla, jotta saa noparin auki.
Edellämainittuja pikkuvikoja lukuunottamatta, pidän todella paljon tästä noparista. On ensimmäinen sensorillinen, joten sen puolesta ei ole vertailukohteita. Mutta en ole katunut ostosta. Hieman tuon ison kondensaattorin asentamisessa meni aikaa, jotta löysi hyvän paikan.
Hieman myös pelotti, onko vaikea ohjelmoida ilman tietokonetta. Ja vielä mitä, naurettavan helppoa ohjelmoida. Katsoo haluamansa toimenpiteen ohjeesta ja painaa numeron mieleen. Sen jälkeen virtakytkimen viereisestä napista nappi pohjaan ja lasketaan valojen välkähdyksiä ja säädetään arvot samaisella napilla. Paljon helpompaa kuin piippauksen avulla säätäminen!
En vastaa virheellisistä tiedoista, tiedot kopioitu suoraan Novakin sivuilta.
