HobbyKing.com Alennuslinkkilista jotka voimassa 14pv
Aloittaja sprawl, 30.08.11 - klo: 10.37
JoniR
#210
Axial Honcho, LRP S10 SC
CubaLibre
jeskei
Tilattu 15.8.2012, voimassa 14pv, 29.8.2012 asti
Huom. tuotekoodit (listassa tuotteen nimen alla) ovat vain referenssiksi. Tuotteen alennetut hinnat näkyvät vain jos tuotesivuille menee näiden linkkien kautta. Listassa näkyvät alennetut hinnat ovat tämän viestin kirjoitusajankohdan hintoja, ne saattavat muuttua.
TURNIGY 4 in 1 Torx Driver (T5, T6, T8, T10)
$4.07
S638B
http://www.hobbyking.com/buddy.asp?code=6C0DCB3C-CD14-49A9-9B7A-7A4A479BBF77
HobbyKing Cell Key - 6s Lipoly Cell checker
$2.56
CELLTKEY
http://www.hobbyking.com/buddy.asp?code=76C4551C-A1F3-4AB6-9533-D087F0602011
Charge Cable w/ Male XT60 <-> 4mm Banana plug
$2.04
601CC-14-30c
http://www.hobbyking.com/buddy.asp?code=CB49964B-98CA-4190-9075-7F7E9A80CF33
XT60 Harness for 2 Packs in Parallel (1pc)
$1.65
601A-2PParal
http://www.hobbyking.com/buddy.asp?code=70622D69-BFBF-496B-9A38-DC5D827630F1
XT60 Harness for 2 Packs in Parallel - Mini size (1pc)
$1.15
258000015
http://www.hobbyking.com/buddy.asp?code=21BF14CF-BFFC-421B-AEC2-CC872C7AF070
Female Traxxas <-> Male XT60 (3pcs/bag)
$2.65
604B-601A
http://www.hobbyking.com/buddy.asp?code=50C39083-FF7D-459D-9856-533588BE87EA
JST-XH 3S Wire Extension 20cm (10pcs/bag)
$2.84
JSTMF-3S-20
http://www.hobbyking.com/buddy.asp?code=F1289ABF-54FE-4935-95B0-1B3EA604156A
De-soldering Braid 2.5mm/1.5m
$1.00
322000006
http://www.hobbyking.com/buddy.asp?code=B17DA5A5-C0F8-4662-B3B1-5B1EC5BF9052
Turnigy Pure-Silicone Wire 12AWG (1mtr) RED
$1.50
R12A1062-06
http://www.hobbyking.com/buddy.asp?code=74BC699C-072B-4DC0-8361-CD84CA9D483A
Turnigy Pure-Silicone Wire 12AWG (1mtr) BLACK
$1.50
B12A1062-06
http://www.hobbyking.com/buddy.asp?code=1CD4A7A9-4A28-4300-918E-4CC1E31B5D0A
Turnigy 5mm Heat Shrink Tube - RED (1mtr)
$0.06
WHS-5MM-RED
http://www.hobbyking.com/buddy.asp?code=F60D2456-255F-4220-9D07-CC52386CDC9E
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
$0.06
WH-5MM-BLACK
http://www.hobbyking.com/buddy.asp?code=B3CF5062-4F18-43B6-BF0A-C8AA659A51DF
Turnigy 50mm Heat Shrink Tube - BLUE (1mtr)
$1.09
WHS50-Blue
http://www.hobbyking.com/buddy.asp?code=2DD724D0-B29E-40DF-8E99-9D305EA30466
Turnigy 100mm Heat Shrink Tube - BLUE (1mtr)
$2.36
WHS100-Blue
http://www.hobbyking.com/buddy.asp?code=69618ECD-E5AA-41B1-B267-D3F791D5C9B3
JoniR
MLA
Tilattu 28.8.2012
CNC Alloy Servo Arm Short (Futaba)
http://www.hobbyking.com/buddy.asp?code=7DE0FE13-E41F-4BE9-A3AC-93A4554F0CA0
Flat 26AWG servo wire 1mtr (R/O/B)
http://www.hobbyking.com/buddy.asp?code=177152B9-554F-4270-8C6D-FE189B33F04E
Servo Terminals (Futaba) Gold Plated (10pair)
http://www.hobbyking.com/buddy.asp?code=DC58B3B0-5A23-466F-9EA3-59E8C1BFC2C5
Turnigy Pure-Silicone Wire 10AWG (1mtr) RED
http://www.hobbyking.com/buddy.asp?code=A18465D2-16E5-4484-9091-C081721675F0
Turnigy Pure-Silicone Wire 10AWG (1mtr) BLACK
http://www.hobbyking.com/buddy.asp?code=69D1BC42-F360-4990-90B5-F3F07046D644
http://www.hobbyking.com/buddy.asp?code=3430A3E7-F9F8-4C4C-98CA-636FCA6B8A78
http://www.hobbyking.com/buddy.asp?code=6E1DC94C-25BC-45A7-ADB7-CC262A82DC4F
Turnigy Heat Shrink Tube 10mm BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=D64F68F1-E13F-4934-934F-2671EA787CE8
Turnigy Heat Shrink Tube 10mm RED (1mtr)
http://www.hobbyking.com/buddy.asp?code=FA5FF927-71E9-46D3-A0AB-9F1EEBACF0BA
Turnigy Heat Shrink Tube 14mm BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=BAB46F58-07C9-4568-A716-7BEE52B2C233
Turnigy Heat Shrink Tube 14mm RED (1mtr)
http://www.hobbyking.com/buddy.asp?code=C64EB30D-F4F9-44BC-A763-0AC83DCD7D16
4MM Banana Plug / Charge Plug (solder type)
http://www.hobbyking.com/buddy.asp?code=6A8EF94F-36C6-4CB6-9CE1-1BBA8F74E445
Clip On Soft Ferrite Rings (5pc)
http://www.hobbyking.com/buddy.asp?code=F7DFD044-DF82-405B-A829-CF0E82A8D7B1
TGY-S4405S 39g / 4.4kg / 0.10sec Dual Bearing, Turnigyn digitaaliservo muovirattailla
http://www.hobbyking.com/buddy.asp?code=A5CB8FE6-BC9A-41E6-A975-DC325B23A0B0
tommys
Tilattu 27.8.2012
Turnigy nano-tech 6000mah 2S 25~50C Lipo Pack
Capacity: 6000mAh
Voltage: 2S1P / 2 Cell / 7.4V
Discharge: 25C Constant / 50C Burst
Weight: 333g (including wire, plug & case)
Dimensions: 155x49x20mm
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-connector
$25.21
http://www.hobbyking.com/buddy.asp?code=0D07C6DC-78B7-4969-A540-795DAD8CE124
vipo
Tässä kaksi eri tilausta mitä tuli otettua tuolta. Lipoja ei otettu tuohon toiseen pakettiin, joten piti ottaa erikseen...  :cry:
Tilattu 29.8
Helikopterin akut:
http://www.hobbyking.com/buddy.asp?code=BA888CF7-0CE6-4444-BB12-BDB561E64A1E
Drift renkaat:
http://www.hobbyking.com/buddy.asp?code=04B8D0EB-26E3-493E-8D3A-63AD8072511C
Tilattu 27.8
601A-XTTB   Male XT60 <-> Female T-Connector (1pc/bag)
http://www.hobbyking.com/buddy.asp?code=73004196-F0EF-419F-AB3E-0CA8CABCFBAE
AM1009x10   HXT 4mm Gold Connector w/ Protector (10pcs/s
http://www.hobbyking.com/buddy.asp?code=4FABC807-8DAB-4B4B-BA48-9BBA28B2883B
WH5008   1:10 Scale Wheel Set (2pcs) Split 6-Spoke RC
http://www.hobbyking.com/buddy.asp?code=8A7312D0-9C41-4A7C-BE06-4917FF9B7D61
B6AC   IMAX B6-AC Charger/Discharger 1-6 Cells (GEN
http://www.hobbyking.com/buddy.asp?code=16477174-FAB9-4AFA-A02B-B5B65A9E6ED9
T-30PS-220   HobbyKing 540w 220~240v Power Supply (13.8v~
http://www.hobbyking.com/buddy.asp?code=A22AA11D-9446-4E89-A641-9FE997E83BC2
9052000003   Turnigy MEGA 400Wx2 Battery Charger/Discharg
http://www.hobbyking.com/buddy.asp?code=4EA1ABC7-F91E-4689-8C36-07751EE02DD9
LEDCARSET02   Hobbyking Scale Car LED Light system
http://www.hobbyking.com/buddy.asp?code=8AAE52D7-5B2E-45C7-B1A6-B43EBB3E9EF7
Q740002   RC Car Camber Gauge - General Purpose
http://www.hobbyking.com/buddy.asp?code=47F37D96-5746-495A-A348-8CC0251D4E00
TY-001   1:10 Scale Soft Rubber Drift Tires w/Removab
http://www.hobbyking.com/buddy.asp?code=D7E4E9E4-BEBC-463B-B4D7-9FA37B7D5150
TY-026   1:10 Scale Soft Rubber Drift Tires w/Removab
http://www.hobbyking.com/buddy.asp?code=184AF2B2-0939-4EFE-9827-DB5B213FFDD2
TY-020B   1:10 Scale Hard Plastic Drift Tires w/Soft R
http://www.hobbyking.com/buddy.asp?code=0D933CA4-8154-4DBB-ACCD-5507CE4B6929
TY-006   1:10 Scale Hard Plastic Drift Tire w/tread R
http://www.hobbyking.com/buddy.asp?code=F09EFB8B-388E-4D8C-8C0B-CD8C70DC1CCC
tuplaesa1
Turok
Tilattu 2.9.2012
9353000060   15T/3.175mm 48 Pitch Steel Pinion Gear
http://www.hobbyking.com/buddy.asp?code=F467E6F6-33B8-4B8B-9E38-17003A6B2423
9353000062   17T/3.175mm  48 Pitch Steel Pinion Gear
http://www.hobbyking.com/buddy.asp?code=8183FEA1-66BE-49A3-8EB1-53D43A1B27BA
9353000064   19T/3.175mm 48 Pitch Steel Pinion Gear
http://www.hobbyking.com/buddy.asp?code=D7F3531C-6BAD-4247-9772-BEE6F5D91236
TL-242   TL-242 Thread Locker & Sealant Medium Streng
http://www.hobbyking.com/buddy.asp?code=207C2F17-1A3A-4E95-8042-7245AAB98D02
AM-1003F   Polymax 4mm Gold Connectors (10pairs/set)
http://www.hobbyking.com/buddy.asp?code=023EC760-66B4-4D32-910A-6A5C46F8551B
calicha92
#223
Tilattu 5.9.2012
ZIPPY Flightmax 5700mah 2S2P 50C Hardcase Car Lipoly
http://www.hobbyking.com/buddy.asp?code=005CE74B-6A1C-466F-9576-E2B4E5347679
On Board Lipoly Low Voltage Alarm (2s~4s)
http://www.hobbyking.com/buddy.asp?code=D654A6D9-5A43-45D0-B0F6-07A915933DC2
HXT 4MM to Banana Plug Charge Lead Adapter
http://www.hobbyking.com/buddy.asp?code=D2D4D9C8-6AE9-4B32-A488-BFFFC43A777C
HPI Baja 5b SS 30,5cc, DEX410V3
Align Trex-450L, 600N, Goblin 380, 570, DX8
Kekkis
dippadaapa
STruck
Missä vaiheessa ostoa sen alennuksen näkee? Ainakin kun tosta otin voimassa olevan linkin niin se hinta on sama kuin normaalistikkin siinä tuotteen tiedoissa.
Zeipii
Ainakin noissa minun linkeissä on suoraan linkin avatessa muutaman sentin alennukset.
Kekkis
Lainaus käyttäjältä: Zeipii - 10.10.12 - klo: 17.11
Eipä muuten näyttäisi olevan, kuten ei mun eikä muissakaan linkeissä.. Hinnan kohdalla pitäisi olla *merkki joka merkkaa sitä että hinta on alennettu, vaan näin ei syystä tai toisesta ole. Olisikohan kyseessä joku bugi, ennen on kyllä toiminut ihan vaan linkkiä klikkaamalla.
Zeipii
#232
Lainaus käyttäjältä: Kekkis - 10.10.12 - klo: 17.41
voikohan johtua selaimesta? itsellä näkyy tähti merkki myös sinun linkeissä. ja uusin FF käytössä.
EDIT: Kirjautukaa sisälle niin tulee alennus näkyviin.
STruck
Okei kiitti vastauksesta vähän mietinkin tota että pitääkö log in. :) Pitää pian ensimmäistä kertaa tuolta tilata ja saa samalla tänne parit linkit porukoille.
Voisiko ekan viestin lähettäjä ( koko threadin alottaja) Pistää siis muokata ekaan viestiinsä että alennukset näkyy kunhan kirjaudut sisään. Helpottaisi tulevia ensikertalaisia :)
STruck
pijokela
TYR RC
Tilattu 5.11
Differential Gear Box Housing will pay only $1.57
http://www.hobbyking.com/buddy.asp?code=7AFBCD05-A73D-43A9-8B70-EB6BD10F9819
Rear Differential Outdrives (2pcs) - Turnigy will pay only $6.45
http://www.hobbyking.com/buddy.asp?code=AE927956-79EC-42AB-A181-4C12E94EB285
tai     ThunderBolt Outdrive Axle (2pcs/bag)  will pay only $8.35
http://www.hobbyking.com/buddy.asp?code=2B9D195E-F7C4-4F43-9C85-7BCECDC29BCB
Pallo päitä nivelille.  (4pcs)will pay only $2.09
http://www.hobbyking.com/buddy.asp?code=5847FF04-02B9-49C7-A2C6-F6DFA034DBDA
Turnigy Pure-Silicone Wire 10AWG (1mtr) BLAC will pay only $2.30
http://www.hobbyking.com/buddy.asp?code=D42D01A9-3A44-41E0-9E74-3A5348DA7C13
Turnigy Pure-Silicone Wire 10AWG (1mtr) RED will pay only $2.30
http://www.hobbyking.com/buddy.asp?code=93935C1E-9B6A-4A7D-8E6C-C8671AFB3040
Turnigy Pure-Silicone Wire 8AWG (1mtr) REDwill pay only $2.46
http://www.hobbyking.com/buddy.asp?code=2D962FA5-D203-40CD-BFC8-6455701AB65C
Turnigy Pure-Silicone Wire 14AWG (1mtr - 69Awill pay only $0.85
http://www.hobbyking.com/buddy.asp?code=90538FC4-5796-43DF-BBC5-5B66D925970C
HXT 4mm Gold Connector w/ Protector (10pcs/s will pay only $3.39
http://www.hobbyking.com/buddy.asp?code=B479748B-9AE4-469D-AD6C-8FA01349483C
