Kirjoittaja Aihe: Markan gigaradiot?  (Luettu 425418 kertaa)
Vs: Markan gigaradiot?
« Vastaus #210 : 06.01.10 - klo: 11.41 »
Joo en mä taida rueta säätämään lipoa tähän, kun ei ole peipalia tai visakorttia, ja suomessa akut kalliita. Huomenna puuiloon hakemaan GP:n 2700mah AA kennoja  :cheesy:. -Sami
Poissa OV
« Vastaus #211 : 06.01.10 - klo: 12.05 »
Koska tuo radio ei tartte 12v toimiakseen. Ylimääränen jänö menee vaan hukkalämmöksi eli 'paistumiseksi'. Ite ainakin tunsin selväsit kotelon läpi kuinka se 2,4ghz moduulin regu lämpeni...
Ja mulla on tälläsistä 'lipo kennoista' tehty nuo akut http://www.dealextreme.com/details.dx/sku.5790
http://www.rcmodelreviews.com/tendollarbattery.shtml
"Go Lithium With Safety!
One of the problems with the standard 3-cell lipo transmitter batteries is that they can be overcharged -- with a resultant risk of fire.
Another problem is that if you forget to turn your transmitter off, these packs can be over-discharged to the point where the cells are damaged and may no longer work.
And, in the case of a transmitter like the 9X using any of the widely available JR-compatible 2.4GHz modules on the market, there are also some risks associated with the very high (often over 12V) output of a freshly charged LiPo battery pack.
Heat Kills
One of the biggest factors in the reliability and life of electronic components is the heat at which they operate. Modern 2.4GHz radios like the 9X don't actually need the full 10V or so that an 8-cell AA pack delivers and they certainly don't need the 11V-12V a 3S LiPo supplies.
That's because, the circuitry inside is designed to run on a maximum of just 5 volts. Yes, up to 6 volts of the power coming from most transmitter batteries will be wasted.
What happens to all that energy?
It's converted to heat. Heat that makes critical components called voltage regulators run hotter than they need to.
It makes a lot of sense therefor, to use a battery that provides "just enough" voltage. Not too much, not too little.
That's where this low-cost lithium battery conversion comes in.
Not only is this an incredibly cheap transmitter battery option but it's also safer and will help your radio run cooler and longer.
En näe yhtään syytä miksi käyttäisin 3s lipoja tässä. Paitsi jos ei sitä sumemria tosiaan jaksa irroittaa... Tuota huutamista ei meinaan jaksa kuunnella erkkkikään. 2s lipoillakin on vielä se vaara, että pääsee valumaan kuiviin. Mutta kun tekee akun noista 'kennoista' niin ei ole sitäkään vaaraa enää.
« Viimeksi muokattu: 06.01.10 - klo: 12.13 kirjoittanut OV »
Poissa Maxximo
« Vastaus #212 : 06.01.10 - klo: 13.34 »
No jos radio on suunniteltu toimimaan 12 voltilla niin kyllä se taatusti toimii täyteen ladatulla 3S lipolla joka on vain 12,6v. Huomattavasti pidemmän ajoajankin saa kun on jännite heti alunpitäen korkeampi. Itellä on tollanen 3S lipo käytössä ilman ongelmia tosin eri radiolla. Eikä tarvi mitään teippi/johtohärdelliä tonne patterikoteloon tunkea...
Poissa OV
« Vastaus #213 : 06.01.10 - klo: 13.43 »
Öh... Luitko tota yläpuolista pränttiä? Ketään ei ole väittänyt, että se ei toimisi. Vaan, että se ei tarvitse 12V toimiakseen. Tuo ylimääräinen jännite menee vain ja ainoastaan hukkalämmöksi ja lämmöstähän komponentit tykkää, mitä kuumempaa niin sitä parempaa...
Niin muista radioista en sano mitään, mutta tämä radio ei ainakaan tarvitse ja ilmeisesti vastaavat missä on sama 2,4Ghz moduuli käytössä.
Tässä nyt sama google translaten läpi huonolla suomennoksella (suosittelen lukemaan ennemmin tuon eng version jos kieli vaan sujuu):
Mene litiumia ja turvallisuutta!
Yksi ongelmista standardin 3-cell lipo lähettimen paristot on, että ne voivat olla liikaa - ja tästä tulipalovaaran.
Toinen ongelma on, että jos unohdat kytkeä lähettimen pois päältä, nämä pakkaukset voivat olla yli-päästetään siihen pisteeseen, jossa solut ovat vahingoittuneet, ja ehkä enää toimi.
Ja jos lähettimen kuten 9X jollakin yleisesti saatavilla JR-yhteensopiva 2.4GHz moduulien markkinoilla on myös joitakin riskejä erittäin korkea (usein yli 12V) tuotos vasta hintaan LiPo akku .
Heat Kills
Yksi suurimmista tekijöistä luotettavuutta ja lyhentää elektronisten osien lämpöä, jolla ne toimivat. Moderni 2.4GHz radiot, kuten 9X ei oikeastaan tarvitse koko 10V tai niin, että 8-cell AA Pack tarjoaa ja ne eivät todellakaan tarvitse 11V-12V 3S LiPo tarvikkeita.
Tämä johtuu siitä, piiri sisällä on suunniteltu toimimaan enintään vain 5 volttia. Kyllä, enintään 6 voltin virta peräisin kaikkein lähettimen paristojen menee hukkaan.
Mitä tapahtuu kaikille, että energiaa?
Se lämmöksi. Lämpöä, jonka avulla kriittiset osat kutsutaan Voltage Regulators ajaa lämpimämpää kuin ne tarvitsevat.
Se tekee paljon järkeä niitä, käyttää akkua, joka tarjoaa "vain tarpeeksi" jännite. Ei liikaa eikä liian vähän.
Siellä tämä edullisia litiumparisto muuntamisen tulee sisään
Ei vain tämä on uskomattoman halpaa lähetin akun vaihtoehto, mutta se on myös turvallisempi ja auttaa radiopuhelin suorittaa jäähdytin ja pidempään
« Viimeksi muokattu: 06.01.10 - klo: 13.51 kirjoittanut OV »
Poissa triheadwolf
« Vastaus #214 : 06.01.10 - klo: 18.22 »
Onhan tuota modattu: http://rc10.fi/index.php?topic=39471.msg374998#msg374998 ja http://rc10.fi/index.php?topic=12567.msg381672#msg381672
Hyvin pelittää 2s:nkin voimin. Ja autom. cut offi niin ei tartte peljätä lipottimien puolesta. Tulee halvemmaksi ja helpommaksi kuin tuo triheadwolffin vastaava 2s viritys. Ja mahheja on samat 2400...
No helpommasta en niin tiedä, halvemmaksi varmaan joo ja virityksiähän nämä on molemmat. En mä tuota omaa ratkaisuani hyvänä pidäkään, mutta näytinpähän nyt vaihtoehdon jonka pöljyyksissäni menin tekemään. Vaikkapa varoittavana esimerkkinä :D
Ei ollu eka eikä jää viimeiseksi sellaiseksi ;)
HPI Savage & Vorza Flux HP, B4.1, vielä kun opettelis ajamaan.
Poissa OV
« Vastaus #215 : 06.01.10 - klo: 22.58 »
Niin no eihän tuo helpompi varmaan ole. Eikä tosta teikäläiseltäkään muuta huonoa tule mieleen kuin tuo, että jos pääsee tyjäksi. Itellä on ainakin välillä paha tapa unohtaa tuo päälle. Toki kun tietää, että sitä ei saa päästää tyhjäksi niin tuskin tulee jätettyä päälle.
Summeri on kutitenkin pakko otaa irti kun se huutaisi muuten kokoajan. 3s lipolla on taas se hyvä puoli, että summeri alkaa huutamaan niin sitä ei niin helpolla tule tyhjennettyä.
Poissa jeslepp
« Vastaus #216 : 07.01.10 - klo: 13.45 »
Tätä onkin odotettu!
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10608
Ainakin halpa, jos ei muuta :grin:
Tänään tuli tollanen postiin. Pitää ruveta heti testailemaan, kun saan käsiin.
TT-01, Xray t2 009. Pari lennokkia
Poissa mikkolah
« Vastaus #218 : 07.01.10 - klo: 17.06 »
Noniin nyt on 3 generaation vastarit tulleet r2hobbiessiin. http://r2hobbies.com/proddetail.php?prod=rcps2806002&utm_source=streamsend&utm_medium=email&utm_content=8164431&utm_campaign=Newsletter%20Jan%20Issue%201
Rusinana pohjalla 1 ja 2 version omistavat voivat päivittää oman ohjaimensa 3 versioon. http://r2hobbies.com/proddetail.php?prod=rcps2806001&utm_source=streamsend&utm_medium=email&utm_content=8164431&utm_campaign=Newsletter%20Jan%20Issue%201
Eilen lähti tulemaan kohti suomea tollanen eurgle. On se vaan aika villin näkönen kapistus  :grin:
Kyosho :: HPI :: Asso + muuta aiheeseen liittyvää..
Poissa SH.
« Vastaus #219 : 07.01.10 - klo: 20.21 »
no voi kökkö :embarrassed: Just mietin.että pitäiskö tilata pari vastaria kun tuo kalusto lisääntyy tuolla kaapissa :wink:
hieman haiskahtaa rahastukselta,mutta ei pahasti koska ei mikään sikahintainen moduuli ole.
PS: jos jollakin on noita 1 tai 2 generaation vastareita  ylimääräisenä,niin ota yhteyttä yv:llä
Poissa miksu5
« Vastaus #220 : 07.01.10 - klo: 20.55 »
ongelma eurglen kanssa....
ongelma ilmenee ohjauksen servon  kanssa
liitin kolmannen vastarin ohjaimeen ja piti aloittaa säätö autolle-> ohjaimesta kun kääntää niin servo kääntyy aina samaan suuntaan pienen arpomisen jälkeen..
"ykkös-paikan" asetuksilla homma rokkaa hienosti vailla mitään ongelmia ja kaikki säädöt olen sieltä  kopioinut, mutta ongelma on ja pysyy kun paikkanro:na on kolme :huh:
kellään mitään ajatuksia ei niin selkokieliseen ongelmaan   :undecided:
kiittäen
kaikenlaisia...rakenteilla tai liikkuvia
Poissa Casull
« Vastaus #221 : 07.01.10 - klo: 20.57 »
Kannattaisiko tähän menevät pari kymppiä ennemmin sijoittaa vaikka alkoholiin?
http://r2hobbies.com/proddetail.php?prod=rcps21216
Hinta ei kyllä ole paha ollenkaan.
Saas nähdä milloin joku hinkuvintialainen tehdas alkaa tehdä FASST-yhteensopivia vastareita järkevään hintaan.
Poissa Hegetus
« Vastaus #222 : 07.01.10 - klo: 21.14 »
kiittäen
Muokkaa valikko "ARC" sieltä steering, sen käyrän muokkaat vasemmalta lähtemään arvosta 0 sitten 25 sitten 50 sitten 75 ja viimeinen 100
Alkaa servo toimia oikein......
Poissa miksu5
« Vastaus #223 : 07.01.10 - klo: 21.43 »
kiittäen
niimpä sepä olikin ainut jota en sitten kopsannut ja auttoi
joten suuret kiitokset :grin:
Poissa Linksu
« Vastaus #224 : 07.01.10 - klo: 22.21 »
Onko kellään tietoa kuin toi failsafe toimii tuossa? itsellä on toi generation 3 Radio ja samat ohjeet siinä on kuin vanhassa eikä puhuta mitään failsafesta.
Poissa Tuumou
« Vastaus #225 : 08.01.10 - klo: 08.41 »
Ei minultakaan löydy mitään failseiffiä valikosta, mutta eikös se failsafe pidä olla siinä vastarissa. Mulla kyllä toimii failsafe 3. versiossa, 2. versiossa ei, niinkuin ei pidäkkään.
Poissa mikkolah
« Vastaus #226 : 08.01.10 - klo: 19.54 »
Ja tänään saapui, saas kahtoa onko mistään kotoisin..
« Vastaus #227 : 08.01.10 - klo: 19.56 »
Menikö vaan 2pvä kun tuli ? Itsellä pitäisi päivittää 3rd generation, kun tulee polttis tähän taloon, niin failsafea tarvitaan. -Sami
Poissa mikkolah
« Vastaus #228 : 08.01.10 - klo: 20.04 »
5. pv illalla laitoin tilauksen sisään, 6. pv tuli email että lähti tulemaan ja tänään toivat kotiovelle :) Olin aika hämmästynyt.. Tosin r2hobbies vissiin valitsee randomilla toimitustavan? mailissa luki "Your order is randomly chose to be shipped by UPS", mahtoko sillä olla osuutta nopeuteen?
Mulla muuta rojua tulossa EMSillä ja ne tilaukset on laitettu aikaisemmin sisään, mutta ne on vieläkin matkalla..
Poissa Linksu
« Vastaus #229 : 08.01.10 - klo: 20.06 »
Onko 3rd:n vastarissa mikä se nappi siinä valonvieressä?
Poissa mikkolah
« Vastaus #230 : 08.01.10 - klo: 20.19 »
Joo, on siinä nappi. Mikäs nappi se mahtaa olla? Manuska ei kerro siitä mitään..
« Vastaus #231 : 09.01.10 - klo: 13.49 »
Kun tässä eurglen lähettimessä on se latauspistoke, niin kumpi siinä on + ja kumpi +. -Sami
Poissa SH.
« Vastaus #232 : 09.01.10 - klo: 14.37 »
Tarkoitat varmaan + ja - ?
Kuitenkin ulompi on - ja sisempi +,iteltäni löytyy hitecin ja futaban latauspistokkeet ja kummatkin menee eurgleen,mutta vain toinen niistää toimii,pistokkeista vain ei erota kumpi on kumpi?
« Vastaus #233 : 09.01.10 - klo: 14.40 »
Jos kyseessä on seinälaturi, niissä on yleensä napaisuus merkittynä.
Niin tai näin, yleismittari kertoo.
« Vastaus #234 : 09.01.10 - klo: 14.40 »
Mulla erottaa, mutta nyt on latauksessa, hitto ku aina typotan kaiken  :cheesy:. -Sami
Poissa Linksu
« Vastaus #235 : 09.01.10 - klo: 20.41 »
Millaisia latausvirtoja käytätte?
« Vastaus #236 : 09.01.10 - klo: 20.42 »
yleismaailmallisesti radioiden töspelin läpi ei passaa ladata kovin isoilla virroilla, joku puol amppeeria on ehkä vielä ok.
Itse lataan radioiden akut aina erikseen.
« Vastaus #237 : 09.01.10 - klo: 21.19 »
Mä laitoin 1 amppeerilla, ei kärynny, vielä  :cheesy:. -Sami
Poissa Linksu
« Vastaus #238 : 09.01.10 - klo: 22.38 »
Joko joku on uskaltanut painaa sitä vastarin  nappia että mitä tapahtuu?
Poissa SH.
« Vastaus #239 : 10.01.10 - klo: 19.10 »
Tähän asti on kestäny kärryyttää 1.5 amppeerilla. :angel:
