Team associated b7 varaosa kitti
Aloittaja mts80, 04.04.26 - klo: 11.08
mts80
92403 toplate and ballstud mount 2kpl
92410 front suspension arms 3kpl
92408 rear suspwnsion arms 1kpl
92420 gear differential case 1kpl
92133 differential gasket&o-rings
92461 geardifferential cap 2kpl
92405 gearbox 1kpl
92454 hd cva bone 69mm 2kpl
92412 rear hubs 2kpl
92448 topshaft screw 2kpl
92447 top shaft 1kpl
91438 cva rebuild kit 1kpl
91436 cva/wheel hex pin 1kpl
92496 hinge pin set 1kpl
91819 shock pivot balls 1kpl
92419 rod ends 1kpl
91973 steering bellcrank and rack set 1kpl
92417 rear wing mount and body mount 1kpl
92415 caster and steering blocks carbon 1kpl
92442 caster block pivot balls 1kpl
92459 front anti-roll bar set 1kpl
91494 machined shock spacers v2 1kpl
91493 Ft low friction x-rings 1kpl
92430 front shock tower 2kpl
92294 octalock spur geat 78t 2kpl
Osien ovh. 480€, nyt 220€ posteineen
0405091280
Laukaa
