HPI Baja 5B
Iigor
Saattaapi sattua  :huh:
"The ouch factor of a full speed Baja
I'm an engineering major and I love my physics classes. The study of physics helps to put things into perspective. I was bored so I did a little calculations to put the Baja's power into perspective.
The kinetic energy of a moving object is given by this equation.
KE=(1/2)mv^2 (one half the objects mass x its velocity squared)
30lbs Baja = 13.6kg (kilograms)
40mph = 17.9m/s (meters per second)
Therefore
KE=(1/2)(13.6kg)(17.9m/s)^2
KE=2178.9J (Joules)
Is that alot?
Put it this way. The equation for the Potential Energy by gravity of an object due to it's height above the ground is given by this equation.
PE=mgh (The objects mass x acceleration due to gravity x height above the ground)
If we solve for the mass an object would need if dropped just 6ft (about 2 meters) above the ground such that it had the same KE as the Baja, we have.
2178.9J=m(9.8m/s^2)(2m)
m=111.1kg
111kg is about 245pounds!!!
That means that getting hit in the ankles by a 30lbs Baja going 40mph will have the same "ouch factor" as a 245 pound object dropped on your ankles from 6ft off the ground!
Of course there other factors like impact surface area, was it inelastic or elastic, and whether your standing against a wall when it his you or not, but in general the numbers don't lie. These things are powerful!
People you need failsafes."
Vois olla jalka tohjona kun baja tulis nilkkaan täysillä. :lipsrsealed:
Iigor
Jauhelihaa, jos sattus olemaan kunnon piikkirenkaat edessä :shock:
rampa
Moro kaikille! Itsekin liityin baja jengiin ja ensitöikseen shimmasin välykset pyöränlaakereista ja tukivarsista sekä kuumailmapuhaltimella lämmitin kaikki pallolinkit timmiin kuntoon. Kyseessä on siis käytetty baja 5b ss. Kytkintä en sen kummemmin tarkastanut, mutta kytkinkellossa tuntui jo pientä monen suuntaista välystä. Autoa senverran kokeilin, että renkaiden väpätys ja huono tasapainotus ihmetyttää! Mitkä olisi parhaat järeämmät ja tukevammat renkaat ja vanteet yleisajoon nurtsille ja soratielle, kun nämä orkkis renkaat ja vanteet tuntuvat kovin alimitoitetulta? Voiko tälläisen bajan 26cc mottiin tarvittaessa vaihtaa pelkän männänrenkaan?
Sammy__80__
Tervetuloa rampa  :azn:
juu noista renkaista ja vanteista  itse kyllä olen ollyt hyvin tyytyväinen hpi:n omiin vanteisiin ja inserrteihin mutta itse päälykummit kyllä kannattaa ostaa joltain muultavalmistajalta esim Hostille. Ja ei kyllä tollasta väpätys ongelmaa ole ollut voisiko se johtua muualla olevasta välyksestä tai insertteihin on päässyt vettä / likaa niin on epätasapainossa.
Yleensä kyllä selviää pelkällä männärenkaan vaihdolla jos ei sylinterissä ole hirmusia pitkittäisiä naarmuja tai kromaus ole päässyt irtoileen imu / pakoaukon ympäriltä. Kytkinkellolle kannattaa kyllä vaihtaa laakeri ensitilassa jos alkaa välyksia ja krahinaa kuuluun lakruista niin säästyy isommalta remontilta.
Saakostiedustella että ostitko ton ss:n nettimerkkinoilta?
Iigor
Kannattaa vaihtaa myös samalla se muovinen lärpäke, missä kytkinkello on kiinni. Jos se on mennyt väljäksi, niin kytkinkello heiluu, vaikka vaihtaisit uudet laakerit.
rampa
#756
Juu väpätys johtuu renkaista/ inserteistä. Niissä oli teippiä ja silloin ne väpättivät enemmi. Navat ovat suorat ja kaikki välykset ovat shimmattu pois. Joo sama laitos.
rampa
Hei, laittakaas vähän listaa mitkä renkaat, foamit ja vanteet olisi parhaat ja kestävimmät normaaliin sekalaiseen ajoon. Oma ajeluni olisi puistossa ja tasaisela soralla ja asfalttilla. Luin koko ketjun läpi, mutta selkeätä käsitystä renkaista ja foameista ei syntynyt. Ilmeisesti näitä parempia tai eri merkkisiä renkaita ei saa suomesta?
Jos jokapaikan renkaat pitäis hommata niin ostasin jotkut näistä. Mitään nappula kumeja ei kannata asvaltille viedä. Ja katurenkailla ei sit asiaa soralle.
Hostile All-Terrain
etu http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5914/.f
taka http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.3415/.f
Pro-Line Excavator
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5583/.f
RC4WD Dune Reaper. Ovat vähän isommat kuin vakio 5B.n kun ovat 5T.hen
Etu http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5926/.f
Taka http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5925/.f
Iigor
5B:hen ostaisin Hostilen All Terrainit....jokainen tietenkin valitsee itse....
savo
Itelläni oli aikoinaan Bajassa samanlaiset nappularenkaat kun FG:n Marderissa tulee. Nurmikolla ja soralla pito oli hyvä mutta tosiaankaan asvaltille nappularenkaita ei kannata viedä... Tulee hetkessä nappulattomat renkaat...  :grin:
Sen takia hommasin ne nappulat koska alkuperäisten takarenkaiden kanssa oli sitä väpätystä ja ravistusta enkä ikinä keksinyt mistä se johtuu. :huh:
rampa
#761
Kiitoksia todella paljon avusta. Onko baja 5b ja 5t saman kokoinen vanne? Eikö se ole pelkkä etu jos renkaan halkaisia hieman kasvaa ja varsinkin jos rengas on pikkasen painavempaan laitteeseen tarkoitettu?
Tässä liikkeessä on ilmeisesti renkaat parihinnoin ja vanteet on kpl. hinnoin? En löytänyt sopivia foameja noihin linkin baja 5t:n renkaisiin.
Tekeeköhän tälläsellä putkella mitään ja pärjääköhän se hpi bajan ss putkelle? Näyttäs DDM Dominator kopiolta, ollen mitoiltaan kuitenkin hieman pienempi. Ajattelin tilata, kun on niin halpa. :-)
KLIKS!
Iigor
Pärjännee ainakin HPI:n omalle tehopöntölle.
Ja halpakin on.
Mutta varmasti on niin ohutta tavaraa, että solmussa heti.
5T vanteet eri kuin B.ssä. Ainakin takana on kapeampi.
Noille Dune Reaper renkaille käy orkkis 5T vanteet, joten orkkis foamitkin pitäis mennä.
Nämä renkaat on samankokoiset kuin vakio 5T.n
Tietysti vielä yksi vaihtoehto on jokapaikan renkaiksi vakio 5T renkaat.
Etu http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5367/.f
Taka http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5368/.f
Iigor
...ainakin parempi kuin HPI:n oma tehari, mikä vasta paperia onkin....renkaina olisin edelleenkin sitä mieltä että Hostile All Terrain.....
rampa
Ilmeisesti tuo KM tehari taitaakin olla terästä? Voipi olla kestävä, mut painoa on varmasti huomattavasti enemmän, kun alumiinisessa? Joten taitaa se mahdollinen tehon lisäys hukkua tuohon lisääntyneeseen painoon?
Lainaus myynti-ilmoituksesta.
"This steel alloy pipe in single piece desigm to ensure no leakage. The item includes spacer, header cooling parts and bolts. A good exhaust pipe is very imporatnt for a 2-stroke engine. With this muffler installed, both the acceleration and top end can be increased!"
Iigor
Mulla on DDM:n tehari, ja se painaa aika lähelle 606g, mutta tuo tehoa melkein hepan lisää verrattuna vakioon. Meno ei ole ainakaan hyytynyt tuolla putkella, vaikka painaakin aika reippaasti :mrgreen: Mulla on auton kokonaispaino tällä hetkellä 13.5 kg.
Toisaalta, jos laitat tuohon vähän pätäkkää lisää, niin saat "merkkiputken"....
Iigor
Saataisiinpa joskus tänne kotomaahankin kunnon toimintaa..... http://www.hpiracing.com/bajanats/
Nuo Hostilen All-Terrainit itsekin buggyyn ostaisin.
T.hen liian pieniä nuo 5B renkaat, joten tähän ostan kun joskus tarvitsee nuo RC4WD.n nakit.
Tuli muuten juuri ruuvattua autoon alumiiniset iskaripukit eteen/taakse ja on parit eri säätökohdatkin.
rampa
Onpa ihmeen kallista koko rengaspaketti tulisi maksamaan yli 300$
Elämä on. Tosin onhan nuo vähän isompia autojakin eikä mitään minejä....
wictro
Lainaus käyttäjältä: rampa - 24.03.09 - klo: 23.31
eihän tossa oo enää RC-auto meininki. mit vit.
.w
-Lithium Love Racing-
Tmbo
Lainaus käyttäjältä: bluebeetle - 24.03.09 - klo: 23.54
No jos aletaan tolle linjalle, niin kyllä samalla summalla saa jo henkilöautoonkin renkaat. Taatusti ei oo tehty renkaan valmistuksessa edes mitään kovin ihmeellistä suunnittelutyötä, toisinkuin 1:1 autojen renkaat kehittyy kokoajan.. Mutta jokainen katsoo itselleen sopivan harrastuksen, tai lompakolle.
HN X2
KiBe
Lainaus käyttäjältä: Tmbo - 25.03.09 - klo: 07.38
Eipä tässä Bajan omistajana ole koskaan tullutkaan sellaista tunnetta, että kylläpäs on halpaa :shock: :shock:
MIKKELSONNI
Asiasta voi olla montaa mieltä mut siitä ei pääse mihinkään et on v...n tyhmää maksaa RC auton renkaista 300$ vaan sen takia et joku pyytä niistä noin kerpeleesti!
Iigor
Mikä setti noin kallis on...ja missä?
Varmaan aluvanne setti. Tai sit laskukone on rikki :lol:
Mistä näitä aina tietää, kun tarkempi tieto puuttuu.
230$ näytti mun laskutikku koko Hostile rengas sarjalle kaikkine tarvikkeineen.
Ja tollasessa Bajan renkaassa on tavaraa kymmeniä kertoja enemmän kuin jossain minin renkaassa, joten jos suhteessa katsotaan materiaalin määrään niin kalliimpia nuo pikku renkaat ovat.
Tokihan mäkin voisin ilmasiks noita ottaa, jos joku vaan antas.
Ps: V..... tyhmää maksaa Ferrarista 200000€, kun Ladan saa 10000€.lla  :mrgreen:
Joten sanonta köyhälle on kaikki kallista sopinee tähän.
Iigor
Eihän tolla hinnalla saa vielä edes aluvannesettiä :cool:
Se olikin ihan heittona, kun tuo 300$ aiemmin mainittu ties mistä.
Juu aluvanteet aika tyyriitä.
rampa
