Robitronic Lapcounter System K Ä Y T T Ö K O K E M U K S E T
Aloittaja yleis, 27.04.09 - klo: 15.15
yleis
Onko kenelläkään kokemusta oheisesta kierroslaskentasysteemistä?
- toimiiko hyvin mineillä ja 1/18-autoilla (sisäkäyttö)
- onko muita hyviä vaihtoehtoja pienen budjetin kierroslaskennalle
http://www.racingfactory.fi/tuotteet/TYOKALUT-JA-VARUSTEET-Muut-varusteet/RS160-Robitronic-Lapcounter-System-103855
Robitronics LAP COUNTER is a fully operational lap counting system for all RC-models of all size. The transponders are extremely small and can be mount problem-free in mini RC Cars 1:18, 1:24, etc..
Every tiny and featherweight transponder is encoded with a worldwide unique number. By crossing the start/finish line the emitted signal will be recognised and processed by the receiver module mounted to the lap counting bridge.
The system is capable of processing many transponders simultanously and independent from the number of receiver modules installed. The number of receiving modules required just depends on the track width under the counter bridge.
Using the included software (and a PC) it is possible to start timed practice sessions immediately.
The system will be delivered in a set with 3 personnel transponders, 4 receiver modules, a PC interface with data cable and the RCM Beginners software with a training program.
    * Features Lap Count System for RC-Cars all sizes
    * For Indoor and Outdoor Tracks
    * Unlimited cars running at same time
    * Personal Transponder with unique ID
    * Small (only 12x16x7mm) and lightweight Transponder (3g)
    * Professional Software for all Windows Systems No. RS160 Lap Counter System
    * 3 Personal Transponder
    * 4 Receiver Modules for tracks with 1.5m width
    * PC-Interface with data cable
    * RCM-Beginners-Software with Trainingsprogram http://www.robitronic.com/lap-counter-en.html
kemi
Eikö kellään ole kokemuksia ko. laitteesta.
Olimme hankkimassa ko. laitetta mutta jäimme odottamaan tälle topicille tulevia postauksia mutta kukaan ei vastannut. Eikö joku voisi laittaa kokemuksistaan hieman tarinaa tänne?
Makke
Merilapista
Ei hankittu mekään vaikka aikeissa oltiin (GT luokkaa ajatellen).
Mielelläni olisin lukenut / kuullut minäkin kokemuksista.
Syy miksi jätin hankkimatta on se, että pitää rakentaa silta; ja meidän radalla (Tattarisuo) se tarkoittaisi sillan kasaamista ja purkamista joka kerta erikseen. Jollain radiosignaalilla toimiva laitteisto miellyttäisi itseä enemmän kuin infrapunalla.
juska
Me ostettiin meidän team:ille ko. sarja. Laitellaan kokemuksia kunhan päästään koittamaan. Ei ainakaan ponderin koko päätä huimaa... about:15mmx15mmx5mm.
Racers Group Finland Team
kemi
tommilk
Mikkelin kerholla tuo järjestelmä on ollut nyt käytössä reilun kuukauden ja osittautunut ihan päteväksi Mini-cup käytössä. Lukee kierrokset hyvin, kun ponderi sijoitetaan maalaamattomaan kohtaan korin sisäpuolelle. Toimintavarmuus ollut hyvä, ainoastaan yksi kolmestatoista ponderista on mykistynyt.
Laitteiston edullinen hinta mahdollisti hankinnan tuohon käyttöön, MikUA:n kustannukset n.200€ peruslaitteistosta, jokainen osti itse henkilökohtaisen ponderin n.30€/kpl ja vanha läppäri saatiin lahjoituksena, ei ole raskaat kustannukset kenellekkään. Käsittääkseni kaikki ovat olleet tyytyväisiä tuohon ratkaisuun.
Varmasti tuhansia maksavat laitteistot toimivat paremmin, mutta niiden hankkiminen täällä ei ollut mitenkään mahdollista eikä järkevää.
yleis
Lainaus käyttäjältä: tommilk - 01.05.09 - klo: 11.10
Kiitos tiedoista!
Onko "juska" päässyt vielä testaamaan laitteistoa?
juska
Ei olla vielä keritty testaamaan. Keskiviikkona "yritettään" saada hepeneet radalle. Joo kyllähän se meilläkin tuo hankintahinta oli se syy miksi tuohon päädyttiin ja se että kun se on oma se on aina mukana kun menee ajamaan.
yleis
Lainaus käyttäjältä: juska - 03.05.09 - klo: 10.03
Oletteko päässeet vielä testaamaan kierroslaskuria?
TLCfani
#10
Tuolla ainaki on hyviä kokemuksia, suositellaan http://mini-zracing.com/blog/_archives/2006/4/20/1898903.html
Samoin täällä, ei hirveesti moitteita, ainoastaan että perusohjelmisto on hieman turhanki perus, ja kehittyneempi on liian monimutkanen. Toiset oli laittenu juniorit opettelemaan sen kehittyneemmän, niin sitte homma pelas. :cheesy: http://mini-zracer.com/forums/showthread.php?t=25297
Täällä ollaan kans tyytyväisiä, testattu kahella lähettimellä ja antaa tasaset tulokset, ainoa moite oli jollaki ollu ku ei rekisteröiny maaliin tuloa katollaan. :lol: http://forums.radiocontrolzone.com/showthread.php?t=224872
Karvajalka
Taannoin vähän tutkiskelin noita kierroslaskureita, Robitronicissa tosiaan ainut miinus näytti olevan tuo softatuen puute. Eikä mukana tulevaa tai lisämaksusta saatavaa PRO-versiota oikein kehuttu. Tosin kuten tuossa TLC mainitsikin, penskat kyllä oppi sitä käyttämään, joten tuskin se nyt ihan mahoton on. Valinnanvara ei koskaan kuitenkaan olisi pahitteeksi.
Sikäli AMB-yhteensopivana I-Lap vaikuttaisi vähän kiinnostavammalta (ja vähän kalliimmalta myös). USB-tuki ei myöskään ole paha juttu nykyään koska noi sarjaportit alkaa olla katoava luonnonvara. Robitronic tais olla sarjaportti-only ratkaisu?
No sarjaportti/usb konvertteri ei montaa euroa maksa tänäpäivänä.
TLCfani
Lainaus käyttäjältä: jaan - 28.07.09 - klo: 23.40
Lainaus käyttäjältä: Karvajalka - 27.07.09 - klo: 11.06
Samaa miettisin myös. Mutta en enää.
Manuaali tuolla. http://www.robitronic.com/files/download-en/manuals/electronic/lapcountermanual_en.pdf
Mietit sarjaporttia, vai tätä systeemiä? Miksi et mieti enää, ostitko tämmösen vai jonku muun?
jaan
Jos minua tarkoitit, niin halusin vain tietoa enemmän koko laitteesta.
Kiinnosti laitteen käyttöjännite yms. koska meidän ajot pää-asiassa ulkona ja ilman varsinaista verkkovirtaa. (välillä)
Kai sellainen tarvitsee hankkia testiin niin saa siitä kokemusta ja voihan sitten sitä käyttää pienemmissä autoissa taikka laittaa kiertoon.
jaan
Nyt on laitteesta käyttökokemuksia.
Yllätyin positiivisesti toimivuuteen ja kyllä se laskee kierrokset kun autolla mennään kovaa portin alta. Jopa sekin tuli yllätyksenä että, ohjelma tajuaa sen mistä suunnasta ajetaan joten "huijaaminen" ei onnistu. Myös liian nopeasti ei uudelleen voi ajaa.
Mitä tähän softa puoleen tulee, luulin että laitteen mukana tulee jokin kehittyneempi versio kuin ilmaiseksi ladattava RCM Beginners.
Paremman ohjelman saamiseksi ei investointi ole suuri. Kehittyneempi ohjelma RCM Voice ja se versio joka puhuu maksaa huimat 20€. Tilaukseen kuuluu sen jälkeen päivitykset mm.
RC-Timing sijaitsee Sveitsissä ja ainakin asiakaspalvelu tuolla pelaa mallikkaasti.
Suurena miinuspuolena voisi mainita, ohjelmia ei saa Suomeksi mutta tuo naapurimaa Ruotsi kyllä listoilta löytyy. Kuten aina..
Ponderi on pieni kuten kuvista on saanut ihmetelläkin.
Todellisuudessa tuntuu pienemmältä ja tulee mieleen että se menee hukkaan helposti.
Ponderin sijoittaminen ei tullutkaan ongelmaksi. Asso b4 etuikkunasta tunnisti virheittä.
Traxxas slash rtr koppa valitettavasti maalattu ns. umpeen, mutta etuiskaritornin kohdalle kun leikkaa pienen aukon ja kiinnittää ponderin iskaritorniin. Siitä huolimatta virheitä ei tule, vaikka on kuitenkin 3-5cm päässä kopan alla joten ponderi näkee vastaanottimet vain kohdalla.
Bensa-autossa lähinnä MCD:ssä tuli koitettua myös. Etuikkuna luonnollisesti paras paikka.
Ulkokäytössä kun näitä testejä on tehty, on ajettu vain hiekkapintaisella radalla kuivalla sekä kostealla kelillä. Märkä savi onkin varmasti oma juttunsa, joten en lähde edes ajattelemaan mitä tapahtuu siinä vaiheessa, kun se tuulilasi on sitten savessa.
Slashin sisällä tuli ponderin pintaan hiekkaa jonkin verran. Mutta siitä huolimatta virheitä ei tullut ja kierroksia tuli ajettua reippaanlaisesti.
Laitteiston laajentaminen helppoa. Vastaanotinsilta tarvitsee itse tehdä. Kaapelissa on muistaakseni varaa ainakin 5-6 lisävastaanottimelle, joten leveyttä saadaan käyttötarpeen mukaan ilman mitään virityksiä.
Lisävastaanottimet maksavat alle 40€ kpl, ponderit alle 30€ kpl.
Kaikin puolin hyvä ja halpa ratkaisu verrattuna kalliiseen AMB laitteistoon. Varsinkin jos kerho on pieni.
Eikö se muttenkin näin mene rc puolella, kun vaihtoehtoja tulee markkinoille.
Täh.. Lipo akkuja mitä? Harjaotonmoottori? Me ollaan ajettu vain nimheillä ja hiilellisillä koneilla. Tuollaiset helikopteriakut ja moottorit, ei koskaan tule kisalaillisiksi.
:laugh:
tuusita
Kiitos arvostelusta. Hyvä tietää, että soveltuu moneen ympäristöön.
Kyllä nyt taitaa meidänkin kerholla paineet kasvaa tämän hankintaan...  :grin:
RC-harrastajalle:
Ari-Pekan RC-sivut
Walkera CB100-kopo, Tamiya Mini Cooper, LRP Sharkki Monsteri ja Turisti
Nostetaan vanhaa kun on taas ajankohtainen...
Onko kellään kuvia toimivista ponderiasennuksista?
Ja mieluiten SC-autossa...
Tarkoitus on laittaa ponderi eteen koritolppien väliin ja raaputtaa korista maali pois tältä kohdalta. Toimiikohan noin?
Kuinka tiheästi pitää lukijoiden olla sillassa jotta SC-auto ei mahdu välistä? Kannattaako neljällä lukijalla edes kokeilla kun radan leveys on ~3m vai pitääkö ostaa heti lisää?
JSJ
#19
Maalin poiston sijaan leikkaisin reijän koriin. Jos meinaa uutta koria maalata niin silloin kannattaa jättää ponderin kohta maalaamatta. Reijän/kirkkaan kohdan tulis olla noin 4 cm halkaisijaltaan.
Jos se maalin poisto ei onnistu todella hyvin, niin sitten ihmetellään kun ei laske kaikkia kierroksia.
Muistaakseni Kotkassa kaikilla oli ponderi autossa takana. Ei tainnut monilla johto ylettyä eteen. Kuvia ei tähän hätään ole. Tarranauhalla vaan kiinni iskaritornien väliin.
4 lukijaa on liian vähän 3m leveydelle. Ostakaa pari lisää, tai kaventakaa rataa lukijan kohdalla. Ulkomuistista sanoisin, että meilla on lukijat 30-40cm välein ja silta on ehkä 60-70cm korkeudella. Siltaa korkeamalle nostamalla voisi vähentää lukijoiden määrää mutta sitten alkaa lukutarkkuus kärsiä. Myös korkeamalla on vaikeampi pitää lukija varjossa kun aurinko paistelee eri suunista.
EDIT: Kyllähän se lukijasilta pysyy helposti varjossa. Tärkeämpää on pitää se alue lukijan alla varjossa.
Asso B44.1, SC10 FT
Kitooosh Honkala :smiley:
Onko muilla käyttäjillä jotain lisättävää?
Stinde
LRP-Areenalla on Robitronikki ollut käytössä noin 1,5 vuotta off-road radalla ja hyvin pelittää.
Areenan Krossi ja Korri Kupit on ajeltu kyseisellä ajanotolla , yleisesti ottaen toimii kuin "junan vessa".
Toki muutama ponderi on mykistynyt kovassa "pommituksessa"...  Ja joskus Windows tekee omiaan  :wink:
Osalla on ponderille leikattu reikä koriin ( linssin kokoinen ) ja ponderi suoraan koriin kiinni.  (Useasti tarvitsee jatkojohdon vastarille.)
Toisilla taas ponderi on ikkunan kohdalla rungossa kiinni ja hyvin on toiminut niinkin.
Sellainen huomio on tehty että jos ponderi on vinossa vastaanottimiin nähden , niin luenta heikkenee radikaalisti.
Vastaanottimia on sen laattakaapelin joka liittimessä ja puomin korkeus radasta on noin puoli metriä.
FG ChallengeLine #26
RS5 T15 #26
Lainaus käyttäjältä: Stinde - 24.05.11 - klo: 14.38Sellainen huomio on tehty että jos ponderi on vinossa vastaanottimiin nähden , niin luenta heikkenee radikaalisti.
Näitä asioita kannattanee huomioida kun kierroslaskentaa Espoon radalle asenellaan.
Turun arenahan on sisärata ja siis kierroslaskennan kohtalla täysin tasainen.
Ponderi siis oletettavasti on varmasti suurimmilta osiltaan lähes joka kierros samassa asennossa ja korkeudella vastaanottimiin nähden.
Stinde
#23
Jep, sisällä ajellaan. Eli auringonpaiste ei pääse häiritsemään "lukuprosessia".
Ajanottolinja on ollut myös "veloromin" alastulossa ja siinäkin se toimi. Jos auto tuli oikein päin mäkeä alas  :grin:
Mutta tasaisella radan kohdalla tietysti saavutetaan varmin toiminta ja jos vielä mahdollista niin hitaampi kohta radasta takaa useamman "hitin" ajanotto-ohjelmaan.
Toki toimii pääsuorallakin ja ulkona , niinkuin Jaan taisi kirjoitella tuolla aiemmin
Sen verran vielä jälkimarkkinoinnista, että pelkkää positiivista sanottavaa on meikäläisellä.
Alkuaikoina ponderit oli nelinumeroisia ja kun markkinoille tuli viisinumeroiset ponderit LRP-Areenan systeemi tökki vastaan. Postia netinkautta ja päivityssofta putkahti takaisinpäin , jolla ongelma poistui.
Toinen tapaus toisessa järjestelmässä oli kun vastaanottimissa havaittiin sellainen ongelma , että yksi toimi laattakaapelissa OK mutta kun pisti toisen vastarin kiinni ponderien luenta loppui. Taas postia menemään ja takuuna tuli postin mukana uudet vastaanottimet. Vanhat vastarit sai pitää , eli korvaukseksi vaivoista sai yhden extra vastarin systeemiin.
RS5 T15 #26
Fillarimies
Nyt saatiin vihdoin ja viimein Meri-Lapin pienoisautoilijoillekkin robitronicin ajanottolaitteisto asennettua.
Olin kyllä yllättynyt miten helppoa tuo systeemi oli asentaa. Käytännössä se oli 30min asennukseen ja kovaa ajoa..
Sitten olin positiivisesti myös yllättynyt siitä kuinka hyvin tuo infrapuna toimii. Meillähän ajetaan siis pääasiassa mineillä ja ponderit asennettiin niin, että tehtiin kattoon pieni reikä ja kakspuoliteipillä ponderi koriin kiinni. Siihen jatkojohto ja vastariin kiinni. Tehtiin niin, että pojat ajo ja mie laskin kierroksia niin kyllä se vain jokaikisen portinläpi menon rekisteröi. Ei mitään ongelmia, vaikka meillä on periaatteessa liian vähän vastaanottimia "sillassa".
Meillä on 2m leveä matto ja nyt on 4 vastaanotinta n. 80cm korkeudella matosta, joista viimeinen vastaanotin hieman käännetty vinoon, jotta saa katettua koko ajoalueen.
Ei huono hankinta 200e laitteistoksi.
Plussat:
- Halpa
- Toimintavarma ainakin sisäajossa
- Asennuksen helppous
- Pienet ponderit
Miinukset:
- Portti on vähän estämässä näkyvyyttä
- Tietokonesofta on vähän turhan simppeli
Nparts
#25
Tilasin tuollaisen lapcounter paketin. Kaikki näyttää simppleiltä ja selkeeltä, paitsi adpaterin liittäminen läppäriin. Tuossa on 9-pinninen liitin ja tietenkään koneessa sellaista ei ole.
Onko tuohon liittimeen olemassa toimivaa, esim. USB-sovitinta, vai onko tuo 9-pin liitin ainoa mahdollisuus (ts. hankkia toinen kone)?
EDIT:
Lainaus käyttäjältä: bluebeetle - 28.07.09 - klo: 23.59
Eli tämä on ihan käytännössä toimivaksi todettu ratkaisu?
Tikkeri
Itsellä ainakin 1:1 auton ruiskun säätö tapahtuu kyseisen 9pin liittimen kautta ja tähän on olemassa toimivia usb adaptereita kunhan ei sitä halvinta mahdollista osta.
Xray 808 2009
Powered by: Tyhjä lompakko
JSJ
Kotkassa pikaisesti yritettiin USB sovittimella, mutta ei tominut. Kaiken järjen mukaan sen kyllä saa toimimaan varsinkin laadukaalla sovittimella.
Meillä löytyi heti 'hyllystä' vanha läppäri missä oli 9 pinnin liitin niin laitettiin se suosiolla käyttöön, sen sijaan, että olisimme ryhtyneet sen USB sovittimen kanssa enempää yrittämään.
Olisi kiva kuulla toimiiko homma USB sovittimella, koska tuo meidän vanha läppäri voi viimisen piipauksensa tehdä ihan minä päivänä tahansa.
Asso B44.1, SC10 FT
OV
Noista usb-sarjaportti sovittimista olen kuullut samaa moneltakin taholta(eri laiteissa kyllä). Aina ei edes hinta takaa sitä, että toimisi. Joko toimivaksi todettu malli pitäs löytää tai sitten yritys/erehdys periaatteella.
Lepsu
noissa usb-sarjaporttiadaptereissa kannattaa varmistaa että on toimivat ajurit. Itse työkäytössä olen huomannut että kunhan ajurit on toimivat niin adpterit toimii ja olen muutamia malleja käyttänyt eikä ole olleet kalliita versioita.
DB-01 Durga, DEX210
