Tässä ei osaa kohta päättää mitään
Porukalla on niin paljon mielipiteitä latureista
. Melkovarmaan päädyn johonkin ichargerin laturiin + poweri tai PC ATX power.
Kertokaapas sitten mitä akkumerkkejä suositte/käytätte?Mosaksi meinasin tällaista Team Tekin RX8 1/8 Scale Brushless ESC & 4030 2.5D 2050kv Buggy Motor
Tekin’s RX8 is big power in a small package. Based on the proven RS series Speed Control the RX8 takes large scale current demands in stride. Leading the industry not only in power handling ability but size and features with Drag Brake, Neutral width, Throttle Profiles, Voltage Cut Offs for Lipos and much more. The RX8 sits at only 1.5 x 2.22 x 1.46, a small foot print making it easy to install on any chassis. Don’t negotiate the track, attack it with extreme prejudice.
Tekin’s Redline T8 motor series is designed for large scale, high performance competition. Featuring sensors for flawless, reliable on track operation, the T8 provides pro level control and power. Capable of both sensored and sensorless operation, the T8 series motors are the leading edge of large scale RC motor technology. Utilize the torque and speed of your T8 to propel you across the finish line.
Features
Easily Access Programming, Anywhere, Anytime
Drives Sensor/Sensorless Brushless and Brushed Motors
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
PC Interface for Custom Programming
HDAC: High Density Copper Fet Boards
Sensor Plug for Precise Commutation with all Motors
Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Adjustable Drag Brakes
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune Programming
One-Touch Radio Calibration
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (7 steps)
Throttle Profiles (7 choices)
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2s, 3s, 4s, 6s, Custom)
Timing Advance when used with Tekin Hotwire
Extensive Tuning via Tekin HotWire PC Interface (sold separately)
Controls: Forward/Brake/Reverse
Input Voltage: up to 6S Lipo
Continuous Current: 210 Amps
BEC: 6.0V/5.0A
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Throttle Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4" (38.1 x 55.9 x 35.6mm)
ESC Weight Approx: 2.7oz (76.5g)
CNC Machined 6061 T6 Billet Aluminum Ribbed Heatsink Can
Sensored and Sensorless operation
High Current Solder Tabs
Rebuildable Design
Neodymium Sintered Magnet
Precision Engineered for Maximum Energy Conversion
Dual-Plug Sensor Wire Harness
Motor Weight: 4030: 11.5oz (341g) 4038: 14.25oz (404g)
Shaft Dimensions: 19 x 5mm w/flat
Motor Diameter: 1.57” (40mm) / 1.65” (42mm) including fin
Motor Length: 4030: 2.80” (71mm) 4038: 3.0” (76mm)
