Kyoshon uusi takavetokrossari:
http://www.kyosho.fi/modell_detaljer.aspx?ArtNr=01.30068&familj=FamChOff&BildLopNr=01 7075 Machined and angled hard anodized aluminum chassis with sides angled
2 motor layout setups – Rear(3 gear setup) and Mid(4 gear setup)
Smart battery tray: Compatible with short, straight and saddle packs,both mid & rear motor setup
Long Wheelbase : Chassis is now 13mm longer(285mm) for superb stability.
Rear gull-wing suspension allowing more agile turns and stability in bumpy terrains.
Velvet coated big bore shocks with X-Gear springs.
X-Gear lubriants
New high down-force forward cab body
Super low CG design
New Steering crank design
Specs:
Length: 395 mm Width: 249 mm, height: 140 mm; trace (v): 221 mm gauge (h): 201 mm Wheelbase: 285 mm Weight: 1.620 g
