EFRA AGM - sääntömuutosehdotuksia ensi kaudelle
Aloittaja Vesa, 03.10.13 - klo: 12.07
Vesa
goos
#1
Itse en löytänyt mitään himeellisiä ehdotuksia. Suurin yllätys lienee se että nykyinen 25% nitro on laitonta vuoden päästä ja siihen tarvii keksii ratkaisu, luultavasti laskemalla nitro %, joka tietysti muuttaa aika monta asiaa.
Mitään kiirettä ei ole vielä aika on 2016 asti.
LainaaNitro EU law : http://eur-
lex.europa.eu/smartapi/c
gi/sga_doc?smartapi!celexplus!pr
od!CELEXnumdoc&lg=EN&numdoc=32
013R0098
The rule is named: "Regulation (EU) No 98/
2013 of the European Parlia
ment and of the Council
of 15 January 2013 on the marketing and
use of explosives precursors Text with EEA relevance".
From 2nd September 2014, the products able to
be a primary part of explosives , like
Nitromethane or Nitrathe amonium
etc etc are under suspicious eyes... and all EU members must
look carefully after the trade over those.
For Nitro in short resume the situation is:
A.- Under 30 % all OK;
B.- From 30 % to 40 % not possible unless there is
a registered record of every single commercial
transaction (if such is authorized by the EU country member).
C.- From 40 % up.... not possible to shell it to the public.
Our fuel is normally 25% nitro measured by volume
. In this new rules they measure in weight.
Due to the fact that nitro is a bit more dens
e than water and methanol quite a bit less dense than
water, 30% by weight is something like 22-23 % by volume leading towards our so called "25 %"
fuel out of standard markets
Do not forget there are also Na
tional regulations that might be har
der then EU rules and that more
or less all RC dealers if they wish to deal with
nitro in certain percentages needs to have adequate
facilities and a special permission.
Anyhow, the matter is not so urgent, and so that
considered as matter of General Discussion as
the Regulation itself c
ontains at article 16 t
he following provision:
"Transitional provision" : "The possession and
use by members of
the general public of
restricted explosives precursors
shall be allowed until 2 March 2016.
