Speedpassion exige nopari
Aloittaja WRC206, 10.01.09 - klo: 14.06
WRC206
Onko kenelläkään tietoa speed passion exige 1 tai 1.1 noparin teknisistä tiedoista?
Onko noparissa lipo cut off?
Minkälaista konetta nopari kestää?
- Tamiya solar car -
Googlella löytyi:
LainaaSpeed Passion Exige Brushless ESC & Motor
New affordable super small and lightweight Speed Passion Exige ESC, comes with sensorless 17T Sport Tuned JR motor. Latest version 1.1 with new improved hardware and software. Motor limit 11.5T.
WRC206
No hemmetti, itse googletin pitkään ja en löytänyt mitään fiksua,
pitää varmaan opetella käyttämään googlea tai hankkia rillit :lol:
Vielä kun selviäisi se lipo cut off, täytyy kokeilemalla yrittää selvittää.
Google kertoi taas  :wink:
LainaaInput Voltage: 6V - 14.8V DC
NiCd/NiMH 5-12 cell (6V - 14.4V)
Li-Po 2-5 cell (7.4V-14.8V)
Continuous Current: 40A
Max Current: 120A (10 sec)
BEC: 5V/2A
Drive Freq. : 8KHz
Dimensions: 40mm(L) x 28mm(W) x 13mm (H)
Weight: 44g
Recommended motor limits 13.5T or over sensored or sensor-less brushless motor.
(The manual says 13.5T or over motors, but I heard from speed passion it runs 11.5T and over no problem.)
Program Features:
_______________________
Brake/Reverse or Forward>Brake>Reverse
Throttle Profile (2 choices)
Drag Brake On/Off
Drag Brake Profile (2 choices: 15% or 30%)
+ Additional features access by the "Smart DNA ESC Setup Unit" (sold seperatley)
ESC Features:
_____________________________________________________
Runs both sensorless brushless and sensored brushless motors (only in sensorless mode - it has no sensor cable)
Accepts NiCd/NiMH & Lipo Batteries
Programmable Functions (program unit, sold seperatley)
Low Voltage cut-off protection: Speciffically for Lipo batteries
Programable fail safe: if radio signasl from reciever is lost the ESC will shut down. When signal returns ESC will return to normal.
Thermal Overload Protection: If ESC tempature exceeds the defauklt value, ESC will reduce the motor power gradually, untill the tempature returns to normal.
Input voltage overload protection
Start Protection: Protects the ESC and motor in case of a locked rotor.
WRC206
Lainaus käyttäjältä: Heuli - 10.01.09 - klo: 15.39
Program Features:
Drag Brake On/Off
ESC Features:
Onkohan nuo sittenkään oikean noparin tiedot?
Ainoa ohjelmoitava juttu tuossa noparissa on eteen/jarru tai eteen/pakki,
mitään muuta ei pysty ohjelmoimaan, eikä valmistajan mukaan escin ohjelmointi
korttia tuohon vanhaan malliin ole koskaan saanutkaan eikä uusi siinä toimi.
Nämä ovat ainoat tiedot mitä sain lypsettyä valmistajalta sähköpostitse.
Tuolta noi tiedot ongin: http://www.rcuniverse.com/forum/m_7221003/tm.htm
Tuon olettaisin olevan 1.0 vaikkei siellä mitään siitä mainitakaan. Racing Factoryssä varmaankin tiedetään tarkemmin miten eri versiot eroavat toisistaan.
ajomies
AE-Mod
Mulla on juurikin tuo 1.1:nen, eli kuvassa alin.
Siihen kuuluu sellainen pahvinen ohjelmointikortti jossa muutana dip-kytkin.
Siinä saa säädettyä juurikin noita arvoja mitä Heuli oli googlella kaivanut.
