Nyt on se THE servo mihin tahansa autoon löytynyt!
Toimii suoraan 2s lipolla (7,4v), eli ei enää mitään BEC-virityksiä!
http://www.mks-servo.com.tw/servo-02.htmHV 767 Servo
Exclusive motor designed for high voltage applications
Outstanding precision combined with outlandish performance
Operating Voltage: 6.0V/7.4V
Operating Temperature Range: -10 to +60 Degree C
Operating Speed : (6.0V): 0.145sec / (7.4V):0.118sec
Stall Torque : (6.0V) : 25kg-cm / (7.4V) : 31kg-cm
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Case : Aluminum-magnesium alloy shell
Connector Wire Length: 15cm
Weight: 2.79 oz. (79g)
Wire Length: 15cm
Dimensions: 40 × 20 × 45 mm
Deadband:Less than .001ms
