Laitoin Werks racingille viikko takaperin s-postia,tänään tuli vastaus:
-tässä tietoja heidän polttoaineestaan jos kiinnostaa:
(Castor = risiiniöljy)
Yes, there's castor in it. We've found, depending on the fuel used for
comparison, the life expectancy of a piston/sleeve is extended by as much as
20%. It is the exotic lubricant package that took me 3 years to figure out.
The lubricant is superior to anything out there, that's why the engines run
cooler. Also, this is why the spin up quicker, produce more power and at the
same time make the engines last longer. Nobody makes fuel quite like this.
Try it for your self. Run your engine for 10 minutes on odonnell or
whatever you prefer. Note the engine temperature every few minutes. Flip
the cau upside down and dump the tank, next put out fuel in and see what
happens. You'll see a drop in temperature in about 30 seconds. You can then
lean the engine down, and by doing this - increase the runtime.
Its all sounds too good to be true, but it is. We always like racers to do
direct comparisons. We already know what the results are. I've tested
everyone else's fuel of course!
Eric Vasutin
Werks Racing
Suomeksi pähkinänkuoressa:
-On rissaa,meidän polttoaine on parempaa kuin teidän, testaa jos et usko,prkl.
